Vibration in motor WAWAWAWAWA !
Old Feb 19, 2016 | 01:17 PM
  #61
Change the sprockets when you change the chain.
Old Feb 19, 2016 | 02:22 PM
  #62
DrLoch's Avatar
Also, you will need to replace a number of the bolts since they are torque to yield. Vibration damper and camshaft sprockets for sure.
Old Feb 19, 2016 | 05:11 PM
  #63
Cat Man HHR's Avatar
Found this, shows how to check the balancer chain to see if it's tight, without tearing everything apart.
Good find RJ
Old Feb 19, 2016 | 08:46 PM
  #64
dhare1's Avatar
I used this method to check the balancer chain , that's how I found the loose chain that turned out to be the broken guide that the internal tensioner pushes up against . Can't believe the chain didn't fly off.
Old Feb 20, 2016 | 09:13 AM
  #65
I would have thought it would be cogs on cam gear X cogs on balance shaft gears. Something to to with that relation
Old Feb 20, 2016 | 10:44 AM
  #66
The cam gears are driven by the timing chain , the balance shafts drive off the water pump chain
Old Feb 20, 2016 | 12:28 PM
  #67
Yes but they all drive off the crank. To get all 6 of the timing marks to line up again takes a lot of revolutions.
Old Feb 20, 2016 | 01:32 PM
  #68
To be more accurate, the formula is probably based on a ratio of the lengths of the 2 chains. If they were exactly the same length, I would think all 6 marks might line up every 2 revolutions. But they are not the same. And it might be complicated by the ratio of cogs on the crank to cogs on the balance shaft gears, as well as the ratio of cogs on the cam gears to cogs on the crank.
Old Feb 20, 2016 | 03:48 PM
  #69
dhare1's Avatar
I am assembling the new parts today , both tensioners , both cam sprockets , both crank sprockets , both chains , all of the guides , bolts , oil jet . When putting the cam sprockets on is ok for cams to move either way a little to be able to get the chains on ? They moved a little when taking apart and putting together but chain links line up with all timing marks on crank and cam sprockets . They seem to be in the original position when I set TDC .
Old Feb 20, 2016 | 05:53 PM
  #70
Hold the cams with a 24 mm open end wrench or an adjustable crescent wrench
