Vibration in motor WAWAWAWAWA !
Old Feb 20, 2016 | 11:20 PM
  #81
Actually, counting the gaps between the cogs(23) on the gear, it looks like about 4:30. The mark on the balance shaft crank gear lines up with a cog(1st), the mark on the timing crank gear is the 4th cog.
Edit: the cog(1st) is on the cam timing gear on the crank
Old Feb 22, 2016 | 03:16 PM
  #82
DrLoch's Avatar
How is the fix going?
Old Feb 22, 2016 | 05:25 PM
  #83
dhare1's Avatar
The Cam actuators I bought at Napa Auto Parts , They didn't fit . When I torqued them down the inside of the actuator hit the engine case where the cam is mounted to . The depth of the hole where the cam fits into the actuator(where the pin is) was machined too deep making it hit the case . The second issue that I hopefully resolved was when I removed the Napa Actuators the timing marks were a half turn from the 10 and 2 o'clock position and didn't realize it until I installed the new actuators , the crank was at TDC so I installed the timing chain and turned the crank 1 full rotation and the actuator timing marks are in 10 and 2 postion along with crank TDC now. Then i removed all of the chains and lined up all of the timing marks again.I guess 360 degree rotation of the crank turns the cams only 180 degree .
Old Feb 22, 2016 | 05:54 PM
  #84
dhare1's Avatar
Is it safe to say if the crank is TDC and the actuator sprockets are at 10 and 2 o'clock I have it back together correct ?
Old Feb 23, 2016 | 09:14 AM
  #85
There are links I posted for you to confirm the timing marks
Old Feb 23, 2016 | 12:57 PM
  #86
The short answer is: You line the chain up on the cams, then turn the crank to line up to the chain.
Old Feb 23, 2016 | 01:44 PM
  #87
dhare1's Avatar
Thanks guy's I understand the procedure with lining up the timing marks , if you read my #83 post I ran into a problem with new Actuators that didn't fit and somehow when I installed the new replacement actuators the marks did't line up. They were 180 degree's off on both sides , I installed the chain and turned the crank 360 degrees and the actuator marks landed on 10 and 2 o'clock with crank at TDC . Could I have messed something up or is it safe to say as long as the timing marks are 10 and 2 o'clock and crank at TDC everything is where it should be ?
Old Feb 23, 2016 | 01:56 PM
  #88
Yes all lined up, did you turn the crank while the chain was removed??
Old Feb 23, 2016 | 02:04 PM
  #89
dhare1's Avatar
I did not turn the crank while the chain was removed .
Crank was TDC when I removed the defective new actuators
Replaced new actuators and noticed marks were approx 4 and 8 o'clock ?
Installed chain and turned crank 360 degrees
Actuator marks turned to 10 and 2 o'clock and crank is TDC
Old Feb 23, 2016 | 02:06 PM
  #90
And where are the cam sprocket marks? 2 for the intake side and 10 for the exhaust?
