Warped Rotors
Old May 27, 2012 | 12:27 AM
Hotrodbob's Avatar
Warped Rotors
After 60,000 miles my SS is showing signs of rotors being warped. I just changed to a non-OEM pad and within a few weeks the front end wobbles on braking.
Question: 1.)what rotors do you recommend? 2) what pads that limit dust and don't squeal do you use?
Old May 27, 2012 | 06:14 AM
Question. Do you have the Brembo brakes?
Old May 27, 2012 | 07:38 AM
Gary B's Avatar
Check and see if there are Raybestos pads and rotors available. They are excellent! Every GM vehicle that I have owned has had Rotor pulsation after a while and each has been rectified with Raybestos parts. My HHR is smooth during braking and has been for twenty five thousand miles now. There is also no dust issues, or noise.
Old May 27, 2012 | 08:14 AM
At 60k Bob, your rotors may be on the thin side, and combined with the new pads(probably more aggressive than OEM I'm guessing), they've just given up and turned into "potato chips" on you.
As Gary said, Raybestos makes some really good pads, or there are places like EBC with low dust compounds. I'm sure more SS owners will weigh in here over the long weekend.
Old May 27, 2012 | 08:38 AM
Old Lar's Avatar
At 92K miles I had rotors, pads, drums amd shoes all replaced. I had no pulsing or brake issues and the components all were still in good condition. Cars that have "premature" wear or pulsing you need to evaluate your braking techniques.
Old May 27, 2012 | 08:55 PM
Hotrodbob's Avatar
No, early 2008 SS, not sure they were available yet.
Thanks
Gee, I thought 60K miles in L.A. traffic was good for brakes. Ya think that's "Premature", Really? I'm not complaining about this, just wanted input. Just a quick repair job I can do, but interested in Rotor and pad options others are using. Drilled or slotted rotors and I was thinking of EBC parts as well.
Old May 28, 2012 | 09:06 AM
IgottaWoody's Avatar
Just Suspension has some offers for brake packages for the SS..Plain..slotted..drilled and slotted or just drilled...with ceramics..
DanH
Feb 1, 2018 08:48 AM
moosejunky99
20
Oct 21, 2014 04:29 PM
FURIOUS10
27
Feb 15, 2012 10:08 PM
TrapperJohn
Jul 18, 2011 12:11 PM
Rob
Sep 30, 2007 04:21 PM
