Weird intermittant loss of power
Old Oct 8, 2012 | 03:37 PM
pitbull76's Avatar
Occasionally, I will find that my car will only boost to 5PSI. At first I thought it might be a wiring issue, but when this happens it just will not work until I shut the car off and wait for awhile. An immediate restart will not clear the issue; the car has to be turned off for 5-10 minutes. Also, when this is happening, the BPV sounds very strange when off the 5PSI boost, almost like a fluttering sound. After the car sits maybe 5-10 minutes the turbo is back, but the car will surge badly. It will surge for the next couple times I use it, then go back to working properly for days or weeks before going through the whole thing again. It has never set a CEL during any of this. Has anyone experienced this and found a solution?
Old Oct 9, 2012 | 11:31 PM
5280_SS's Avatar
Yep mine problem started the same way. Sounds like a GM upgrade may be giving you some problems. Do you have to crimped connectors or the new kit? If you look around you will see a lot of people with the same issue. Might be able to compare some symptoms to narrow it down.
Old Oct 10, 2012 | 06:40 AM
pitbull76's Avatar
Believe me; I've had a few other problems and read about just about all of them, but I can't recall ones quite like I'm having now. I have had the problem with reduced clearance on the lower sensor, and that would cause an intermittent "limp mode" to happen, but those would come and go as I was driving the car; I wouldn't have to shut the car off for 5 minutes to reset it. I have also had an issue with a boost leak due to shoddy installation of the stage kit which caused the car to go into limp mode, but that could be cleared immediately by turning the car off and immediately back on and it set the CEL.
The issue I'm having now isn't like either of those, and with no CEL I'm not sure where to look. This sucks. Any help would be appreciated.
Old Oct 10, 2012 | 11:04 AM
JoeSchmoe's Avatar
I had an intermittent boost problem with no CEL. It turned out to be a vacuum pump (?) that wouldn't hold vacuum properly.
I will check my service records when I get a chance to see exactly what they replaced and let you know.
Old Oct 10, 2012 | 11:12 AM
pitbull76's Avatar
Did yours loose boost for the whole drive, or would it drop and come back? Also, did it immediately return on a restart, or did you have to wait awhile like I have? Thanks for your help!
Old Oct 10, 2012 | 11:43 AM
JoeSchmoe's Avatar
When it dropped, it would stay dropped until the car was turned off and restarted. It never came back while still running.
Particularly in 1st gear it would bog down more so than other gears.
If the car was shut off, the boost would return upon restart pretty much every time. I don't know about the timing though as I am not sure if I ever turned it off and immediately turned it back on or if it was off for several minutes to hours before I fired it up again.
Old Oct 11, 2012 | 07:54 AM
Tominator's Avatar
I had the same problem. My dealer spent a lot of hours diagnosing and fixing the car. They are mailing me the complete work order, parts list and electronic data.
They gave me a new Cruz LT to drive for the week they had it.....very disappointing car and wouldn't have traded my 3 year old SS for it even up!
Anyway, when I get the paperwork from the dealer I'll post it up.
Old Oct 11, 2012 | 08:43 AM
pitbull76's Avatar
I would appreciate the information. I am also curious how often yours acted up. Mine only seems to act up once every few weeks and can sometimes go nearly a month before having the problem again.
Old Oct 12, 2012 | 10:31 AM
Not to hijack the thread, but I'm curious as to what Tominator didn't like about the Cruze.
Old Oct 12, 2012 | 10:47 AM
Let me guess, it's not a SS.
