08 SS need tires
Old Nov 10, 2013 | 12:51 AM
bobiroc's Avatar
08 SS need tires
The stock Michelin tires finally need to be replaced which I am glad because they suck. I found these and thought I would run it past you guys
http://www.tirerack.com/tires/tires....omCompare1=yes
General G-MAX AS-03
245 40/18
One thing that concerned me is the rim size recommendation. They say these should be used on a 8-9.5" width rim and I thought the stock SS Rims were 7.75
I also was hoping to get something closer to a 60,000 mile treadwear rating but that might be a lost hope with a performance tire.
If anyone has any other recommendations in a 245 size tire I am open to suggestions and I would love to order a set soon. My stepfather is a mechanic and manages a shop so he can install and balance them for me.
Thank You in advance
Old Nov 10, 2013 | 02:48 PM
I wore out a set of those, go over 40k , great tire. I replaced them with 235x45x18 Michelin pilot sport as3 and they are even better.
Old Nov 10, 2013 | 02:58 PM
bobiroc's Avatar
The Michelin's are considerably more expensive for the same size tire it seems.
I was also looking at a set of Nitto tires which seem to offer similar performance but a longer treadwear rating
http://www.discounttire.com/dtcs/fin...145&vid=018831
Nitto NT 555 Extreme
Old Nov 10, 2013 | 05:10 PM
bobiroc's Avatar
Anyone know the rim width of the HHR SS stock wheels? I have read they are 7.5, 7.75 and 8 so which are they.
If they are less than 8 should I worry if the tires I am looking at recommend a wheel width between 8-9.5?
Old Nov 10, 2013 | 05:45 PM
Stock SS rims are 7.5".
Tried to take a picture of the stamping for you but it didn't focus.
Old Nov 10, 2013 | 05:47 PM
bobiroc's Avatar
So if the 245 size tires I am looking at are recommending a 8-9.5 width rim should I be concerned?? I have heard people putting up to 265 size tires on the stock rims. I just want to make sure if I order tires online that they will fit.
Old Nov 10, 2013 | 06:25 PM
bobiroc's Avatar
OK I have narrowed it down to these
http://www.tirebuyer.com/tires/nitto.../p/tv154000378
or
these were recommended by a friend
http://www.tirebuyer.com/tires/conti.../p/tv119001238
Not sure if the continentals are worth the extra price though
Old Nov 11, 2013 | 01:03 AM
The gmax run narrow I had 255x40 on 8" wheels. I tried DWS in the past and got a little hydroplaning in deep water.
Those Nitto's look interesting but I'm sure 245x45 wont work.
I paid 450.00 out the door for the Michelin, how could I say no.........
Old Nov 11, 2013 | 10:09 AM
bobiroc's Avatar
Well the two narrowed down choices both state they will fit on a 7.5 wide rim. Why do you say they will not work?
Old Nov 11, 2013 | 10:54 AM
I think it will be too tall . I have done 235x45x18 on the stock wheels and there wasn't room for a credit card between the spring perch and the tire. But all manufacturers make them a tad different the only way to say for sure is to mount one and slip it on to see.
