15" Wheel Size Question
Old Apr 5, 2017 | 02:47 PM
cooltravlin's Avatar
Thinking about going with 15" wheels and some RWL Tires, question is will 15" wheels with proper 5x110 spacing fit a 2008 HHR LT.
Old Apr 5, 2017 | 02:55 PM
You would also need to take backspacing and tire size into account.
EDIT: Offset and rim width would also be important information. You could take all this info to a website (tirerack, discounttire, etc.) and plug it into a calculator.
Old Apr 5, 2017 | 03:55 PM
Fit, yes. Fit safely, I don't know. The law says only the the tire and wheel listed on the placard is safe.
The 5X110 is the definition of the bolt circle, so any rim with that bolt circle will "fit" on the hub, maybe not legally.
Old Apr 5, 2017 | 07:17 PM
Some 2004,5,6 Malibu's had 15 " rims with the 5 on 110 mm bolt pattern 40 mm offset
https://www.tirerack.com/wheels/resu...4&autoModClar=
Davyo
Tires & Wheels
Aug 22, 2011 11:08 AM
Lethal Tendencies
Tires & Wheels
Feb 16, 2010 09:11 AM
PrimerFender
Tires & Wheels
7
Mar 23, 2009 06:23 PM
MindDrive
Tires & Wheels
7
Feb 1, 2009 07:21 AM
