Wheel Size Question
Old Dec 31, 2009 | 07:49 PM
Lethal Tendencies's Avatar
Wheel Size Question
If I go from 16 to 18" wheels will it effect the speedometer?
Old Jan 1, 2010 | 12:29 AM
IgottaWoody's Avatar
Just keep the overall diameter of the tire the same and no problem.....
Old Jan 1, 2010 | 10:58 PM
prod's Avatar
Going to 18" I would get tires that are 235/40/18, just a hair bigger than stock. The wheels should be 5x110 bolt pattern, 7.5"-8" wide, with an offset close to 42mm.
Old Jan 2, 2010 | 01:01 AM
txbass06's Avatar
I went from the stock 16" LS wheels to a set of 18" Cobalt SS/SC wheels with the 235/40's. With my speedometer showing 60, I'm actually doing 60.2
Old Jan 2, 2010 | 01:51 AM
I wanna bump too. but just to 225/50/17.....Any bigger I'd need wider rims.
Old Jan 2, 2010 | 09:54 AM
Thats exactly the swap I was thinking of doing.Thanks for the info.
Old Jan 2, 2010 | 10:02 AM
Would a 225/50/18 work?
Old Feb 16, 2010 | 12:46 AM
Try using this tire size comparison link.. It even tells you what the MPH would be diff from stock tires...
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Feb 16, 2010 | 09:11 AM
txbass06's Avatar
The 225/50/R18 would have your speedometer off by approximately 4 MPH at 60...
john whalen
Tires & Wheels
Oct 20, 2011 10:54 PM
PrimerFender
Tires & Wheels
7
Mar 23, 2009 06:23 PM
z28nate
Nov 20, 2008 11:39 AM
DreamHHR
Apr 12, 2007 03:50 PM
chuktaylor2
13
Jan 17, 2006 11:12 PM
