18" Tire Size?
Okay, I'm a little ignorant on this and pretty much anything else that has to do with vehicles
but I have just purchased a set of CSS rims and curious if 235/40/18 will fit and look good?
Thanks!
but I have just purchased a set of CSS rims and curious if 235/40/18 will fit and look good?Thanks!
Just my thoughts
! Since you didn't lower the Front End you may want to consider 225 x 45 x 18's
! You sacrafice a slight amount of width but will fill the wheel well gap slightly
! Either one of the two sizes is a great way to go
Good Luck,
! Either one of the two sizes is a great way to go Good Luck,
265/35zr18 w/18x8.5 wheels on the front with goldline lowering springs=no rub and great traction. The ride seems okay although I have nothing to compare it to as I put it all together when I had 21 miles on the vehicle.
Thanks DLVRNIT! That link to use for comparison is sweet.
I was curious on the size because I found a slightly used set of Michelin Pilot Sports in this size for $350 local and that is a lot easier on the ole wallet than ordering a new set.
Here's a pic with my son's cobalt wheels w/goodyear Eagle GT's 225-45-18
not crazy about the black paint on wheels, rides well on these tires. will receive the gunmetal cobalt rims mon., and will post a pic also. Sons cobalt now sporting g6 gtp rims which I may slap on my car for another pic. After this rim swapping, going to let him chose which ones he intends to keep for his birthday
present.
https://www.chevyhhr.net/forums/atta...1&d=1243714579
present.
but under many coats of clear was a gloss black paint that would not come off as easy. Ended up going over it with a soft brass brush on my dremel tool.
https://www.chevyhhr.net/forums/atta...1&d=1248626337
