18 x 9.5 Rim Question
Old Dec 13, 2009 | 09:14 PM
harleysshhr's Avatar
Originally Posted by ocosta1
Yes the bolt pattern is 5 x 114. I'm considering just widening the holes and using wider bolts. 5 x 114 is just a hair larger than the 5 x 110 on the HHR. I wonder if anyone has accomplished this as well.
You can't do that. Firstly, you'll loose the lug seat. secondly, you can't get it perfect enough and it will vibrate. It has to be done on a machine designed to do that and you will need to press in inserts. It costs about $40 per wheel.
Old Dec 13, 2009 | 09:30 PM
Originally Posted by SSguy
Does anyone think that the additional rim & tire width, may put more wear & tear on the wheel bearings & etc ???
I know it looks much cooler, but...........
Really not enough to make any difference. I think one would have more wear and tear from constant rapid accelaration than anything else. I could understand having an adverse effect if the offsets were way crazy and the geometerics of the bearing load were changed negatively. You know, one just can't worry about every little thing in life either. If that were the case no one would ever consider buying a SS HHR over a stock one.
Old Dec 14, 2009 | 12:12 AM
Well, I'm not worried about it, just commenting... And not everyone wants an SS, I know I do not.. I prefer "Built & not bought"..
And when ya buy the SS, it IS stock..
Old Dec 15, 2009 | 06:14 PM
IgottaWoody's Avatar
Hmm....in this case the SS stock will still put out more then a built LT.. and the SS can be built on top of all that, which is already being done, and not that expensive either...since you'd have to go turbo or SC to even get close, your costs are way higher and we won't even get into long term reliability.......
Besides, when you buy an LT.. also stock...and slow...lol!
Old Dec 15, 2009 | 10:39 PM
IgottaWoody-
Straight over your head, that's wasn't the point at all..
betterof2evils4
Apr 3, 2017 08:34 AM
FargoFlash
Jul 12, 2011 04:54 PM
