2011 HHR LT plastic chrome hubcap things
Old Aug 23, 2011 | 11:47 AM
hhrfever's Avatar
Hi, I have a 2011 HHR LT. It came with "chrome" (really plastic) hupcaps. Regardless of the fact that they are cheap plastic things, the main problem that I have with them are that the lugnuts are made of cheap black plastic and they are always loose feeling. They nuts have yet to fall off but they are just always loose feeling.
I have not check but are there real steel lugnuts under these plastic hubcaps that are holding the tire in?
Does anyone else have an LT that came with these plastic caps and loose plastic nuts?? Maybe since they is a 2011, the Mexican factory just decided to go cheap and make everything plastic.
There was a user who made a similar post about this and he said his "decoration lug nuts" were made of rubber and not plastic and that there are real steel nuts underneath the cap.
https://www.chevyhhr.net/forums/general-hhr-4/hubcaps-2010-lt-29778/
Did all 2011 LT's come with plastic "chrome look" hubcaps and not real chrome?
I guess I should just cough up some cash and get some real chrome hubcaps..
Thanks.......
Old Aug 23, 2011 | 12:16 PM
LawDog88's Avatar
plastic covers over steel nuts.
Old Aug 23, 2011 | 01:13 PM
nacademus's Avatar
https://www.chevyhhr.net/forums/showthread.php?t=29778
Thanks.......
Those plastic lugs just retain the hubcap. There are steel lugs underneath-those plastic lugs just seat on the crown of the threads. You can try tightening them a little, mine were loose when I bought the car new. BE careful though, its only plastic. You should look into buying alloy wheels. there are many different styles and quite a few that were stock to the HHR. Even the newer Malibus, G5s and G6s, 5 lug Cobalts, some Saabs, and some Saturns have wheels that fit the HHR. It just needs to be 5x110mm bolt pattern.
Here is an eBay search that could help you.
http://www.ebay.com/sch/i.html?_from...All-Categories
Old Aug 23, 2011 | 03:33 PM
to the forum hhrfever!
Just to second Officer1151 and nacademus, you're looking at plastic nuts threaded onto the proper lug nuts, if they feel loose just snug them up with your lug wrench...not too tight though, or they will crack.
The 2011 1LT models came with the 16" chromed fascia spoke wheel covers as standard, the 2LT models came with the Chroma-Tech aluminum alloy wheels as standard.
Although the plastic nuts look and feel cheap, its dang near impossible to lose a wheel cover retained that way, just check them for snugness every once and a while.
Old Aug 25, 2011 | 10:46 AM
hhrfever's Avatar
Thanks.
Thanks for all the help guys. Real informative info here. Cheers! Have a good weekend!
Old Aug 25, 2011 | 10:48 AM
LawDog88's Avatar
Salud!
Old Aug 25, 2011 | 01:26 PM
You could also add a drop of Blue Loc-Tite on the plastic nut threads..
Old Aug 25, 2011 | 01:31 PM
nacademus's Avatar
Or, just teflon tape them...
Or do what I did...Name:  IMAG1082.jpg
Old Aug 25, 2011 | 01:35 PM
Don't laugh, but in a pinch even using wifeys fingernail polish will help them stay tight & you can easily remove plastic lugs when needed..
PS: Don't tell wifey..
Old Aug 25, 2011 | 04:28 PM
Just remember that wifey's nail polish goes on the threads, not on the outside, people laugh and point at hot pink lug nuts.
