Aftermarket wheels & Tire Pressure Monitor sytems
Old Mar 4, 2008 | 07:27 PM
hnewagn's Avatar
No tpms in 06
Old Mar 5, 2008 | 04:08 PM
FUTHRRE OWNER's Avatar
Tom,
Thanks for the instructions. I'll give it a go.
-Pat
Old Mar 5, 2008 | 07:39 PM
TomR00's Avatar
If you go to page 5-65 of the 08 Owners Manual the procedure is there also.
https://www.mygmlink.com/pdf/go2cont...et/2008hhr.pdf
TomR
Old Mar 6, 2008 | 09:52 AM
Tom,
Thanks again. I did the procedure last night and it worked perfectly.
-Pat
Old Jun 18, 2008 | 02:42 PM
Canada Jeff's Avatar
Can TPM sensors be fitted to aftermarket wheels?
If this has been covered before, forgive the new guy. I tried searching around but came up empty.
I have an '08 with the now standard TPM system. If I wanted to switch to aftermaket rims, can I install four new TPM sensors on the new rims so the system will still work?
Old Jun 18, 2008 | 02:46 PM
ChevyMgr's Avatar
Yes if they will fit the rims and someone reprograms them afterward.
Old Jun 18, 2008 | 04:30 PM
If the alternative is to just live without them, will this make my computer go nuts and send me snotty OnStar emails about my failing tire pressure sensing system?
What to you guys with aftermarket wheels do?
Old Jun 18, 2008 | 04:49 PM
Dirtsurfer's Avatar
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem These work fine in my 07 panel. Didn't care for the black standard looking valves.
Old Jun 18, 2008 | 05:02 PM
Snoopy's Avatar
Wasn't this discussed in another thread dedicated to the same issue?
Old Jun 18, 2008 | 07:55 PM
vstar's Avatar
I had to buy new valve stems.... GM PART # 15263240
