Offset question.
Old Sep 10, 2015 | 10:09 PM
nrvous1's Avatar
Offset question.
I did a quick search through the mobile site through my phone and didn't see a result for definitive answer to my question.
I got a lot of solstice wheel threads with backspacing questions and I think I saw a post about the stock 17" wheels being 42mm offset? My question is, will the wheel specs posted below fit on my 2011 1Lt? The only suspension mod I have is canuck springs. The wheel specs are...Size: 17x7.5
Offset: 42mm
Backspacing: 6.10"
Bolt Pattern: 5-110
Rec. Tire Size: 205/50-17
Weight: 21.8lbs.
Any help would be appreciated.
Old Sep 10, 2015 | 11:51 PM
I believe they'll work for you, HHR's will tolerate 38-42mm offsets, and the rims you're considering have the proper 5x110mm bolt pattern.
Here's a handy rim/tire calculator that a bunch of us have used for ages....
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Just remember that the O.D. of the tires cannot exceed 26-26.2", or the inner sidewalls will foul on the lower front spring perches, causing nearly instant tire damage.
Old Sep 11, 2015 | 07:19 AM
Stock 17 inch LT rims will fit all years 06 to 11, unless you swapped a set of Brembo brakes up front, they require the SS 18 inch rims
Old Sep 11, 2015 | 11:59 AM
nrvous1's Avatar
Great! Thanks for the replies.
Old Sep 11, 2015 | 01:38 PM
Don't forget to torque them, 100 ft lbs!
Old Sep 11, 2015 | 02:43 PM
And recheck the torque after about 50 miles, and then again after 250 miles of driving, you'll be surprised to see how much the lugs back off initially.
Old Sep 11, 2015 | 03:54 PM
I some times get apart an 1/8 th to a 1/4 of a turn on the WV rally rims
And an 1/8 th turn on the stock steelies
Old Sep 11, 2015 | 04:54 PM
I would suggest a taller tire than the 205/50/17. That size specs out right at 25 inches.
A little taller tire will have more sidewall which should give a better ride.
Old Sep 11, 2015 | 07:37 PM
And a bit taller 26 inch tire givesore circumference, which give better fuel mileage.
Old Sep 11, 2015 | 09:46 PM
nrvous1's Avatar
Thanks.
The wheels I'm looking at have that sized tire mounted and were used for a couple of winter seasons. I really don't think I'll be running those tires since they are snow tires, but it's a package deal. Living here in south Texas I doubt I'll ever see snow again in my life time.
