ordered the studs
OK, so this begs the question, how thick are the spacers you are using? With the 15mm spacers there shouldn't be enough threads on the stock M12x1.5 studs to work correctly and safely. Dang I'm confused here, or are you saying the lug nut holes in the rims are deeply recessed enough to negate the need for longer studs? To meet the minimum safety standards for spacers you've got to be able to thread the lugs on at least six threads worth of the studs.
I saw some nuts like that, but I wanted to make sure I have 8 turns to tight. I might be over doing it but I do lay a few more ftlb's on them around 350.
I was temped to do both, but the guy's from H&R, make them for Porsche, they said 7 was enough.
it was more than enough to use the set up i have 843 the people said it was safe . i had the wheels off awhile ago doin some painting and there is enough threads for the lug nuts to be safe. if it wasnt i wouldnt be using the studs
