ordered the studs
Old Feb 4, 2012 | 05:24 PM
capp002's Avatar
no stud change here just lugs n spacers
Old Feb 4, 2012 | 05:35 PM
OK, so this begs the question, how thick are the spacers you are using? With the 15mm spacers there shouldn't be enough threads on the stock M12x1.5 studs to work correctly and safely. Dang I'm confused here, or are you saying the lug nut holes in the rims are deeply recessed enough to negate the need for longer studs? To meet the minimum safety standards for spacers you've got to be able to thread the lugs on at least six threads worth of the studs.
I saw some nuts like that, but I wanted to make sure I have 8 turns to tight. I might be over doing it but I do lay a few more ftlb's on them around 350. I was temped to do both, but the guy's from H&R, make them for Porsche, they said 7 was enough.
Old Feb 4, 2012 | 06:28 PM
capp002's Avatar
it was more than enough to use the set up i have 843 the people said it was safe . i had the wheels off awhile ago doin some painting and there is enough threads for the lug nuts to be safe. if it wasnt i wouldnt be using the studs
Old Feb 4, 2012 | 06:38 PM
capp002's Avatar
843 your goin to make me pull a lugnut off to show you looool
Old Feb 4, 2012 | 06:44 PM
  #26
It's just cause we love you man, just count the revolutions, I have been mislead by others before, we just want you to be safe, as in all 4 wheels on car.
Old Feb 4, 2012 | 10:55 PM
  #27
Yup, just concerned about your safety capp and that of others doing the same wheel fitment, having a wheel "take a vacation" on you is no fun and does tons of damage.
Old Feb 5, 2012 | 10:46 AM
  #28
capp002's Avatar
thanks alot guys feelings are the same. but everything is ok with the car its been checked by to dealers because i wanted to be sure as well
Old Feb 5, 2012 | 12:05 PM
  #29
Six thumbs should cover it
Old Feb 5, 2012 | 05:31 PM
  #30
capp002's Avatar
loooool i hope so
