scuffed wheel
Old May 1, 2011 | 01:15 AM
chi-girl's Avatar
scuffed wheel
I have the original wheels that came on my 2010 HHR SS. I scuffed my wheel today. Can it be polished? Will it need to be clear coated again. Will it be expensive?
Old May 1, 2011 | 01:26 AM
Welcome chi-girl...
A pic of the damage would be helpful.
However if the "scuff" is not too bad, it could be polished out. If it is more severe, it could be sanded, using finer & finer grades of wet / dry sandpaper & then polished.
But you will be thru the clear-coat. If you are handy, you should be able to do this yourself, or have a friend.
You can use some rattle-can clear coat to keep costs down. But won't be as
good as the oem coating. But would still work fine.
Just sayin..
Old May 1, 2011 | 07:07 AM
WELCOME to the site Chi-Girl
Old May 1, 2011 | 08:16 AM
Welcome and Greetings! To echo sleeper's advice, the extent of the repair is dependent on the damage. If its really bad you can also have it done by a wheel repair service, check your yellow pages.
rallyist
Tires & Wheels
0
Feb 13, 2013 10:27 PM
phuture
Tires & Wheels
Mar 19, 2011 10:56 PM
shazammy
Jul 31, 2010 05:05 AM
