Srvc Tire monitor?
Old Jun 5, 2013 | 07:23 PM
nick60's Avatar
Srvc Tire monitor?
My panel doesn't show the pressure for my right rear tire. A message says srvc Tire Monitor. Can someone tell me what that means? Thanks, Nick60
Old Jun 5, 2013 | 07:27 PM
jczboy's Avatar
You probably Had a TPMS sensor go bad. Battery is supposed to last 7 years or more, but don't always
Old Jun 5, 2013 | 10:29 PM
Sidecardog1's Avatar
I second jczboy's response. I have had that on a few occasions and wound up having a total of three replaced. The dealer can attempt to retrain the sensor with their tool and it may do the trick. Otherwise, the tire bead has to be broken from the wheel rim and a new sensor (valve stem) installed. There is a little blurb in the owners manual about the sensor transmission being interferred with othe nearby signals from other sources, but usually it is simply the battery in the sensor going bad.
Old Jun 5, 2013 | 10:45 PM
X3 You've got a sensor that's gone goofy Nick, the battery life seems to be about half of what GM claims.
Old Jun 6, 2013 | 09:13 PM
But, you didn't say..... does it go back to normal after you turn the engine off then back on? If that's the case then it's fairly normal temporary loss of signal, don't worry about it.
Old Jun 22, 2013 | 06:10 PM
nick60's Avatar
No it just stays on when the car is started. Are there a small batteries in all four sensors in the wheels?
Old Jun 22, 2013 | 10:09 PM
The battery is integral with the sensor. You cannot just change a battery.
Old Jun 28, 2013 | 05:30 PM
jimfet's Avatar
I have an 09 and have replaced two. One this year and the other two years ago. It was fixed under warranty.
Old Aug 2, 2013 | 08:54 PM
working on it's Avatar
I had a right rear sensor that would suddenly fail at about the same location on my drive home. It did this every other day for two weeks, but I had no opportunity to service the tires/sensors at that time. Then, the problem went away. No idea why...perhaps the increasing heat in the tires at this time of year (tires gain 5 lbs pressure on my drive home, in 100+ degree heat). The problem hasn't re-occurred in a month, now.
Old Aug 2, 2013 | 09:31 PM
IgottaWoody's Avatar
Mine did that for most ofa year before i finally changed it....same spot everyday
