Tire Pressure Monitoring FAQ's
Old Jan 28, 2019 | 10:54 AM
  #91
cturboaddict's Avatar
Originally Posted by donbrew
If the Snap on tool can read the numbers it is supposed to be able to insert them into the correct slots.
The OEM one in my hand at the moment is 25920615 It came off an HHR in the junkyard. For rubber stem. Mitchell say the number is 22853741
Which stem came on your wheels?
Rubber stem bud.
Old Jan 28, 2019 | 11:02 AM
  #92
FYI-
Snap On TPMS tool worked as follows during the procedure.
1. Initiate Learn procedure via key fob key on on auto light off.
2. Start at Drivers Front wheel- put scan tool to TPMS, would register on scan tool, horn would never honk or move light to next tire. Scan tool would say move to next.
You would walk around entire car with the scan tools direction, but the horn or lights on car would never change. Eventually timing out. Each tire would register on the scan tool, but the car would not recognize.
  #93
tpms.com says all of the numbers we have cited are interchangeable.
Ok that is a diiferent tool than I was thinking. If the shop has a computer tool they can retrieve the ID numbers from the TPM and insert them into the correct position in the RCDLR.
Old Jan 28, 2019 | 11:26 AM
  #94
Had 2 shops look at it. (The one I was at, and the shop across the street) They both said it was incompatible with the computer.
All of them are using the Snap On TPMS3 tool.
Old Jan 28, 2019 | 11:44 AM
  #95
Cat Man HHR's Avatar
Buy four of the correct ones from someone else. When you get them test it next to the car with one wheel off away from car. If it works install them and return the others.
Old Jan 28, 2019 | 12:26 PM
  #96
Apparently neither shop knows how to use the tool.
Old Jan 28, 2019 | 12:31 PM
  #97
There are high odds of this.
Old Jan 28, 2019 | 12:37 PM
  #98
The more I think about it; I wonder if the tool could make 2010-2011 TPM programmable without the special tool by lying to them about what year to be programmed for.
Old Jan 28, 2019 | 01:06 PM
  #99
Here's another video looking at the screen if you notice the valve stem looks to be inserted into the tool.
Old Jan 28, 2019 | 01:08 PM
  #100
Quick sensor at .35
Chevrolet HHR. at .38
