Tire Question!!!
Old Feb 7, 2010 | 11:41 PM
Originally Posted by Blue Lightning
I've got the "Chicken Hawk" Firestone 215 50R 17's. Is it possible to change the tire to a 225 or 235 60 17? Has anyone done this and how was the ride afterwards?
Blue Lightning
Use this tire comparison calculator, it also gives you the MPH differences.
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Feb 8, 2010 | 01:42 PM
moonsign's Avatar
Not sure about the 17's tire sizes, but at the dealer I bought my SS, I saw a HHR-LT with custom rims, and 235-40-18 tires. I checked and there was plentry of clearance.
So 235-40-18's will work on my SS when it's time for tires. With my Trifecia tune in, it won't be long. "Moon"
Old Feb 15, 2010 | 09:43 PM
jay loukakis's Avatar
Thumbs up had to buy new rear tires today.
they were the stock firestones the tread looked like new, had a tire shop compress the sidewall many cracks the tread would have come off the tires were mfg. in 2006, firestone had this problum with fords some years back, went with Falken have had them before and liked them, i have never had a compression test on tire sidewalls, something to think with Firestones.
Old Feb 18, 2010 | 06:48 PM
unique_w's Avatar
Tire size
Comparing the 215/50/17 to -
225/60/17 is about .375" wider, 2.14" larger diameter, speedo 4 mph higher at 50 mph
235/60/17 is about .75" wider, 2.6" larger diameter, speedo 5 mph higher at 50 mph
Some dealers will not sell/install sizes outside those recommended by the mfg.
The wider the tire the less pounds per sq. inch per tire, may be of concern in heavy rain.
Here are some sites if you wish to compare the differences - height, width, revs etc..
http://www.csgnetwork.com/speedocalibcalc.html
http://www.rims-n-tires.com/rt_specs.jsp
Thanks
Blue Lightning
Old Mar 5, 2010 | 12:10 AM
Blue Lightning's Avatar
Sounds like I either need to stick with the size that I have now or just go up to 225's but no more than that correct?
Blue
Old Mar 5, 2010 | 12:48 AM
Blue-
That's what I'm gonna bump to is 225/50/17, little more.
The stock rims are only 6.5" wide.. So any bigger is gonna be too big for the rims imo..
Old Mar 5, 2010 | 06:43 PM
solman98's Avatar
235/40 18 is almost a 1/2" shorter then the 225/45 18. I was considering the 235/40, but wanted the slightly taller tire. I have about 1/3"-1/2" from the top of the tire to the bottom of the strut plate.
I don't know how they would work with stock rims, but some have done 245/40 on aftermarket and had clearance. That will take you to about a 25.7" tall tire. The 235/40 is about 25.40" tall.
Old Mar 5, 2010 | 07:35 PM
SD70M2's Avatar
I've pulled multiple calc.s and they all tell me that the 235/40/18 (and I don't mean that it has to be right, it's just a consensus) will set me about .2 mph faster when my gauge reads sixty, but is that because I had the 16's
Old Mar 5, 2010 | 08:20 PM
tireman1554's Avatar
No; thats because the overall diameter of the the tire larger.
kkavmann69
Tires & Wheels
Aug 17, 2013 09:49 PM
Vcode455
Apr 9, 2012 11:17 PM
RobSSTurbo
Tires & Wheels
Aug 9, 2011 10:15 AM
Derf
Dec 11, 2009 08:03 PM
Ern
Tires & Wheels
16
Jul 22, 2009 06:44 PM
