Tire question
I have found up to an inch of difference in the same stated width. I would suggest to have one mounted and see. I Found the Goodyear F-1's an inch wider but they put some 255's on my stock wheels and the front had room to turn and cleared the spring seat,looked horrible on the skinny wheel but it fit. Depending on the tire I'd try on a 255 x 40 some T1R's would hook you up !!
Do you have a discount tire, I just went in and asked, they mounted one up to see. I like the 255 cause the height is 26.4 and the stock height is 26.3 so in addition to improved traction, and flatter corners, they reduce the gap as much as the spring perch will allow.
