Will 19” rims fit my SS
Old Sep 27, 2019 | 03:56 PM
1965ss's Avatar
i have an 08 SS looking to install 19" with a 35 off set was told would fit anyone running this size? thank you
Old Sep 27, 2019 | 04:01 PM
Blue_SS's Avatar
How wide? The lower offset helps move it out, so ... maybe?
225/40-19 is almost the same outer diameter. If you go wider than 7.5" wheel, you limit your possibilities.
But, even at 7.5, are YOUR roads that good? A 3.5" sidewall in Detroit is just plain stupid. You will be buying expensive wheels all the damn time.
Old Sep 27, 2019 | 05:20 PM
Moved from an 11 year old dead thread
Old Sep 27, 2019 | 05:43 PM
And moved to tires and wheels, since this is not an SS specific question.
Old Sep 27, 2019 | 05:55 PM
1965ss's Avatar
8.5 inch 235/35/19
Old Sep 28, 2019 | 02:23 AM
a 35 series tire? Man, your roads there must be laser smooth. Like Blue_SS says you will be buying wheels all the time.
Old Sep 28, 2019 | 08:35 AM
I noticed a harsher ride on the 17” rims on my 2011, from the 16” rims on my 2007.
but the FE3 suspension is much better then the FE1 suspension, I can’t imagine the stiffness of the FE5 SS suspension.
Old Sep 28, 2019 | 08:43 PM
Yep less sidewall will do that (as we know) but the less the sidewall the more the tires cost.. Just can't win..
I'm totally pleased from way back when I up-sized my 17" tires to 225/50/17, lil more sidewall (minimal) but noticeable improvement..
But have to watch, as my speed-o will read like .03 mph slower than I'm actually traveling.
Old Sep 28, 2019 | 09:09 PM
.03 mph? How could you possibly notice that?
Old Sep 28, 2019 | 09:30 PM
I really can't, but the math shows it to be that.. FWIW.
ecaryn
Tires & Wheels
13
Aug 1, 2009 08:54 AM
Randomtask
Tires & Wheels
25
Jan 2, 2009 11:57 PM
chevcat
Jun 21, 2008 07:36 PM
CooLDooG
Mar 14, 2008 05:10 PM
ny5112
22
Mar 20, 2007 06:51 PM
