Will these saab wheels fit an ls that has 16" steels on it?
Old 06-28-2017, 08:47 AM
jimmybob's Avatar
Thinking of buying these wheels with perelli p6 tires, would be cool if I could just bolt them on.
jimmybob is offline
Old 06-28-2017, 08:52 AM
Since the link does not work as posted, it's pretty hard to tell. Try reposting the link again.
whopper is offline
Old 06-28-2017, 08:57 AM
I fixed the link for you, but without specs, it's still impossible to advise you.
RJ_RS_SS_350 is offline
Old 06-28-2017, 09:02 AM
Technical Moderator
If the bolt circle is 5X110 and the offset is around 42, they will fit. If they are for a 9-5 most likely they are.
donbrew is offline
Old 06-28-2017, 09:15 AM
I was able to find it on your website, 16 "x6.5", 5x110mm
SAAB # 400127882
But a Google search of the part number did not find the offset
Old 06-28-2017, 09:25 AM
jimmybob's Avatar
SAAB # 400127882
I was able to find a website that said the saab wheels were et49 and I know hhrs are 42 do you guys think it would rub on the strut?
jimmybob is offline
Old 06-28-2017, 09:59 AM
solman98's Avatar
Someone several years ago someone from here installed Saab wheels and the fit was fine.
solman98 is offline
Old 06-28-2017, 12:24 PM
aradmahogany's Avatar
The hub size and lug nut seat type are critical as well. Research the wheels to find these things out, or just seasrch for the car they were on. Buying non OEM rims can be a pain, but as long as offset is within spec and the seat type as well as hub size, you are good. I measured my American Racing Torq Thrust M wheels before installation, and they were machined perfectly right down to the millimeter. Being that SAAB was part of the GM family, I am sure they will fit and be virtually the same as the HHR. Offset wise, you can safely go to +35 MM. Thats where mine are at. I think that is the absolute lowest you can go, though.
aradmahogany is offline
DCNyberg
Tires & Wheels
08-21-2014 09:49 AM
Mateng
Tires & Wheels
21
04-18-2011 03:31 PM
Sirjenx
0
09-18-2009 05:28 PM
Quick Reply: Will these saab wheels fit an ls that has 16" steels on it?
