wire wheel
Old Dec 15, 2011 | 01:55 PM
Chevy13's Avatar
They aren't going to make hideous wire wheels to fit our cars. It's hard enough finding nice aftermarket wheels due to our bolt pattern. It is still somewhat of a new pattern and only used on Chevys smaller FWD apps.
Old Dec 15, 2011 | 02:39 PM
solman98's Avatar
Originally Posted by Chevy13
If you get them, please do not post pictures....
Just because you don't like them..... Lot's of wheel patterns on member cars I don't care for, but they aren't mine either.
Old Dec 15, 2011 | 03:27 PM
Originally Posted by gucci
New email...From Zenith Wheel, no success. Any other suggestions?
Thank you
Charles
Charles- If you are going for "whole knock off set up" perhaps you could have the mounting bases re-drilled to our specs 5 x 110mm..
Old Dec 15, 2011 | 05:23 PM
gucci's Avatar
wire wheel
Good idea Sleeper. Do I have to look for a special model to keep the offset OK?
Old Dec 15, 2011 | 10:31 PM
desertdave's Avatar
reverse offsets all the way with wide whites!!!
Old Dec 15, 2011 | 11:57 PM
Charles-
I'd say you need to find some with very Positive offset (see pic) to keep the tires under the fenders..
Old Dec 16, 2011 | 01:15 AM
While Dayton doesn't make wheels for the HHR, they do make positive offset rims for the PT Cruiser.
http://www.daytonwheel.com/ptcruiser.html
And you can buy wheel spacers/adapters to get you from the Cruiser's 5 X 100mm bolt pattern to our 5 X 110mm pattern.
http://www.roadkillenterprises.com/5...00-to-5-x-110/
So this would be one option to consider Charles, you would have an offset that is going to end up somewhat "wrong" but if you absolutely have to have wire wheels its one way to go.
Old Dec 18, 2011 | 05:51 PM
gucci's Avatar
Thank you 843de,I will write to Roadkill and Dayton wire wheel to see what they have in stock.
Charles
lefthandedrighty
Dec 23, 2012 08:43 AM
EcotecRacer
Apr 12, 2012 06:25 PM
DrTrapper
Oct 7, 2011 08:40 PM
Putter
Jan 3, 2011 12:20 PM
1HotHHR
Tires & Wheels
Oct 25, 2008 03:05 PM
