How to Replace HVAC Blower fan/motor
Old 02-20-2014, 11:24 AM
paulBvtn's Avatar
Yeah the drawing of the utility knife cutting something seemed really unclear. The plastic itself is actually much better to look at.
But yes I would not have attempted in the first place if I didn't read the service manual.
paulBvtn is offline
Old 11-15-2014, 06:51 AM
08HHRPA's Avatar
Here's a video of replacement in Cobalt. Similar setup, but no rivets to drill on HHR, just remove the nuts. Shows where to cut. It's clearer on full screen. . . . . . .
08HHRPA is offline
Old 12-20-2014, 09:30 PM
edward_mckenna's Avatar
I have only had my 2006 HHR LS for a week and the heater has stopped working. The only way it works is if I put the fan speed on highest setting, but it makes some pretty weird noises. I'm not sure if replacing the HVAC blower will fix this.
edward_mckenna is offline
Old 12-20-2014, 10:23 PM
Welcome to the site.
If your fan only works on the high setting, then you most likely have a bad fan resistor.
Now if the fan itself is making weird noises, then you may also have a bad fan motor.(also possible you could have debris in the fans blower cage: leafs are known to get stuck in there and cause a racket )
Sounds like you may have 2 parts that are bad.
2006 HHR are known for having a water leak issue from the front cowl area. It is caused by a part called the butyl patch.(do a search here for related threads).
The water leaking on the fan motor and resistor is generally what causes them to go bad.
firemangeorge is offline
Old 12-21-2014, 01:40 AM
x2 what FMG said. Let us know how it goes if you can.
whopper is offline
Old 12-22-2014, 02:10 PM
dk1393's Avatar
I found a hacksaw blade to work very well when cutting around the backside of the blower motor. It is a poor design if you ask me.
dk1393 is offline
Old 04-26-2015, 07:05 PM
TheWrightTrack's Avatar
Thank you guys for all your information!
I have just spent all day working on my 2006 HHR Blower motor and resistor.
But due to all the info I found on this forum, I was able to do all the repairs.
Also, yesterday I replaced the hub on the front passenger side, again with help on this forum.
Thanks for posting this relevant information.
Mark Wright
2006 Chevrolet HHR LS Sunburst Orange
TheWrightTrack is offline
Old 04-27-2015, 10:07 AM
Cool!!!
That's what it's all about. We're glad you found the site helpful.
whopper is offline
Old 04-28-2015, 08:48 AM
Nice to see you got the jobs done!!
Oldblue is offline
07HHR_
06-29-2014 09:20 PM
twelvewheels
05-02-2011 08:43 AM
robert4380
11-25-2008 08:52 AM
btccdr
06-16-2006 07:51 PM
Quick Reply: How to Replace HVAC Blower fan/motor
