Stuck in park/but not stuck in park
Old 01-03-2017, 08:35 PM
Sydnika's Avatar
So yesterday my car wouldn't shift out of park. So I left the car alone and eventually It shifted so I could drive. So now if I'm driving and put it back in park I have to wait like 10 minutes and I'll hear a click and I can shift again. What's the problem? What do I need to get fix this time? It's a 09. It's parked on flat ground. Also if I'm sitting in the car with it in park I can hear the click and the doors lock and I'm stuck again until it click and I can shift again. Don't know if this is related to the problem but there is also water leaking in my car on the driver side by the hood release lever so my carpet is soaked. Help please
Sydnika is offline
Old 01-03-2017, 08:51 PM
Technical Moderator
First check you battery.
Then: https://www.chevyhhr.net/forums/prob...27/#post610627
donbrew is offline
Old 01-03-2017, 08:55 PM
Sydnika's Avatar
Originally Posted by donbrew
Thanks. Will do
Sydnika is offline
Old 01-03-2017, 09:25 PM
Technical Moderator
Oh BTW, depending on the exact problem there may be an extended warranty on the shifter.
https://www.chevyhhr.net/forums/gm-r...14632-a-52498/
When mine was doing the same sort of thing I sprayed WD40 on the solenoid plunger.
donbrew is offline
Old 01-03-2017, 10:01 PM
Re: water leak - there can be several possible problem areas. You can check out a few of the fixes members have found, by doing a search for "drivers side leaks"
- one that is pretty interesting is this one: https://www.chevyhhr.net/forums/prob...k-again-36429/
whopper is offline
tloveland
11-10-2015 01:45 PM
payindews
10-27-2013 09:35 AM
cturboaddict
01-10-2012 02:46 PM
Old Ray
03-07-2008 06:56 PM
JT's HHR
06-29-2007 03:59 PM
Quick Reply: Stuck in park/but not stuck in park
