Need new power steering motor
I have read the excellent threads on how to replace the power steering motor in my 07 HHR Panel LS. I have been looking for the part online all evening and except for some used motors on Ebay and Amazon, which I don't want, can't find it. I looked at GM Parts Direct and my local dealer online, it seems everything but the motor is available. Anybody know where I can get one?
The part number for the motor has changed to 19257875.
A quick search turned up the following vendors with it listed.....
http://www.gmpartsgiant.com/parts/gm...-19257875.html
http://www.gmpartseast.com/parts/gm-...motor-kit.html
http://www.hendrickgmparts.com/OEMPa.../19257875.html
Unfortunately due to the late hour here, I couldn't call any to confirm availability.
Thanks for the help. My power steering situation is like others I have read about - the warning flashes, then it goes out, and comes back when I shut off and restart the car. I haven't checked any fuses, etc, don't see the need since it keeps coming back. I am just going to change out what I see as a defective motor with a hopefully improved part and save the receipts. I hope I am thinking right.
Sounds like you are on the right track - hose are typical symptoms of the motor starting to fail as it warms up. Keep us posted on how it goes.
I gather you already found the excellent How-To writeup by Stryker on replacing the motor - here is the link anyways for others that may be following this thread :)
https://www.chevyhhr.net/forums/how-tutorial-library-21/power-steering-motor-replacement-w-pics-31289/
I got the motor from GM Parts Giant for about $85. Crammed myself up under the dash and changed it out - watch out when it drops out, it is heavy - swapped it out, and everything is great again. Thanks for the help! If it does it again it will be a breeze.
I hope you saved your receipt, so you can claim it under the special extended warranty.
http://www-odi.nhtsa.dot.gov/owners/..._ids=14V153000
brazor06
12-11-2022 07:59 AM
