SS Struts & shocks???
I'm new on the board and with my 2008 hhr ss. I hit some road construction blew out a tire, messed up the alignment and now my left strut mount is knocking. I've been looking online to find replacement parts and when I get to the struts I want to order the correct ones. I don't know what the suspension codes are for the ss and I like the way it rides stock and want to keep it that way and I know the ss and stiffer ride than a reg or LT version. Where or what part #'s do I need to replaced my struts and shocks on a SS???? sorry if this had been asked before but I've just got confused a little reading on here and I'm kind of on a time crunch to get this done. THanks.
welcome to the site! :)
the part numbers for the rear LH and RH are the same: 15938031
the front struts are :
RH : 19179738
LH : 20794824
you can find them online either gmpartsdirect.com or crateenginedepot.com (come as a package front and rears from crate website)
RH : 19179738
LH : 20794824
Or, you might try rockauto.com. I got mine there, and they shipped from WI, if I remember correctly. You would probably get them next day in your area.
The suspension code is FE5 for the SS, but you might not need it...
aboard
you can buy them new or used at www.car-parts.com
pretty easy
i bought used ones
i have a used one i would sell for $100 that came off a HHR SS w 12K on it.
shipping will be lil bit cause they are heavy
which side did you blow out
if you have someone w a fed ex acct you can have it picked up at my house which is great since i have stage 4 cancer and pay him for the shiping. if he has an acct he will get a discount
pretty easy
i bought used ones
purple haze
0
09-21-2008 05:20 PM
