TTR Upper Engine Mount
Old 08-02-2013, 11:02 AM
  #101
Former Sponsor
TurboTechRacing's Avatar
Any questions let us know, more shipping!
TurboTechRacing is offline
Old 08-02-2013, 07:15 PM
  #102
rlee63a4's Avatar
TTR Motor Mount Installed
rlee63a4 is offline
Old 10-05-2013, 06:09 PM
  #103
Former Sponsor
Looks awesome!
Old 10-05-2013, 07:41 PM
  #104
rlee63a4's Avatar
DRIVING IMPRESSION AFTER 1000 miles
I do feel more vibration when idling, just off off idle and at low RPM, but the vibration is acceptable. Seems I also hear a little more engine noise than before. Most of all, the mount provides the insurance I wanted w.r.t. the A/C compressor hitting the lower GMTU MAP sensor. All in all, I'm more than happy with the mount.
Originally Posted by rlee63a4
rlee63a4 is offline
Old 06-25-2014, 11:26 AM
  #105
Former Sponsor
Thanks again!
Old 07-29-2014, 10:55 AM
  #106
FatTireBiker's Avatar
Are you having a sale on mounts I think I'm about due for one ?
FatTireBiker is offline
Old 09-18-2014, 04:01 PM
  #107
Former Sponsor
Best price is shown on www.TurboTechRacing.com
Old 12-03-2014, 11:41 AM
  #108
Former Sponsor
More in stock.
Old 12-06-2014, 08:40 PM
  #109
Just got the engine mount and the STOP trans mounts. Hoping to install on Monday or Tuesday. I found these torque specs over at cobaltss. Are all these specs correct for HHR? Do I need to mess with frame-to-body bolts and Input Shaft Bearing Retainer Bolts?
Posted by brainchasm
Upper engine mount:
(2) 18mm bolts - 74ft-lbs
(3) 15mm bolts - 37ft-lbs
Posted by ls1fbody, credit goes to Maven for the specs.
F35 ONLY torque specs.
Frame-to-Body Bolts
First Pass
90 N·m
60 lb ft
Second Pass
45 degrees
Final Pass
60 degrees
Front Transaxle Mount Through Bolt
55 N·m
41 lb ft
Front Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
38 N·m
28 lb ft
Left Transaxle Mount Bolts
55 N·m
41 lb ft
Left Transaxle Mount Bracket-to-Transaxle Bolt
55 N·m
41 lb ft
Rear Transaxle Mount Through Bolt
90 N·m
66 lb ft
Rear Transaxle Mount-to-Frame Bolts
60 N·m
44 lb ft
Rear Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
RJ_RS_SS_350 is offline
Old 12-07-2014, 12:42 PM
  #110
Former Sponsor
They all look correct, assuming you got these from the GM shop manual.
