TTR Upper Engine Mount
DRIVING IMPRESSION AFTER 1000 miles
I do feel more vibration when idling, just off off idle and at low RPM, but the vibration is acceptable. Seems I also hear a little more engine noise than before. Most of all, the mount provides the insurance I wanted w.r.t. the A/C compressor hitting the lower GMTU MAP sensor. All in all, I'm more than happy with the mount.
Best price is shown on www.TurboTechRacing.com
Just got the engine mount and the STOP trans mounts. Hoping to install on Monday or Tuesday. I found these torque specs over at cobaltss. Are all these specs correct for HHR? Do I need to mess with frame-to-body bolts and Input Shaft Bearing Retainer Bolts?
Posted by brainchasm
Upper engine mount:
(2) 18mm bolts - 74ft-lbs
(3) 15mm bolts - 37ft-lbs
Posted by ls1fbody, credit goes to Maven for the specs.
F35 ONLY torque specs.
Frame-to-Body Bolts
First Pass
90 N·m
60 lb ft
Second Pass
45 degrees
Final Pass
60 degrees
Front Transaxle Mount Through Bolt
55 N·m
41 lb ft
Front Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
38 N·m
28 lb ft
Left Transaxle Mount Bolts
55 N·m
41 lb ft
Left Transaxle Mount Bracket-to-Transaxle Bolt
55 N·m
41 lb ft
Rear Transaxle Mount Through Bolt
90 N·m
66 lb ft
Rear Transaxle Mount-to-Frame Bolts
60 N·m
44 lb ft
Rear Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
Upper engine mount:
Frame-to-Body Bolts
First Pass
90 N·m
60 lb ft
Second Pass
45 degrees
Final Pass
60 degrees
55 N·m
41 lb ft
55 N·m
41 lb ft
38 N·m
28 lb ft
55 N·m
41 lb ft
55 N·m
41 lb ft
90 N·m
66 lb ft
60 N·m
44 lb ft
55 N·m
41 lb ft
