TTR Upper Engine Mount
Old Aug 2, 2013 | 11:02 AM
  #101
TurboTechRacing's Avatar
Former Sponsor
Any questions let us know, more shipping!
Old Aug 2, 2013 | 07:15 PM
  #102
rlee63a4's Avatar
TTR Motor Mount Installed
Old Oct 5, 2013 | 06:09 PM
  #103
Former Sponsor
Looks awesome!
Old Oct 5, 2013 | 07:41 PM
  #104
rlee63a4's Avatar
DRIVING IMPRESSION AFTER 1000 miles
I do feel more vibration when idling, just off off idle and at low RPM, but the vibration is acceptable. Seems I also hear a little more engine noise than before. Most of all, the mount provides the insurance I wanted w.r.t. the A/C compressor hitting the lower GMTU MAP sensor. All in all, I'm more than happy with the mount.
Originally Posted by rlee63a4
Old Jun 25, 2014 | 11:26 AM
  #105
Former Sponsor
Thanks again!
Old Jul 29, 2014 | 10:55 AM
  #106
FatTireBiker's Avatar
Are you having a sale on mounts I think I'm about due for one ?
Old Sep 18, 2014 | 04:01 PM
  #107
Former Sponsor
Best price is shown on www.TurboTechRacing.com
Old Dec 3, 2014 | 11:41 AM
  #108
Former Sponsor
More in stock.
Old Dec 6, 2014 | 08:40 PM
  #109
Just got the engine mount and the STOP trans mounts. Hoping to install on Monday or Tuesday. I found these torque specs over at cobaltss. Are all these specs correct for HHR? Do I need to mess with frame-to-body bolts and Input Shaft Bearing Retainer Bolts?
Posted by brainchasm
Upper engine mount:
(2) 18mm bolts - 74ft-lbs
(3) 15mm bolts - 37ft-lbs
Posted by ls1fbody, credit goes to Maven for the specs.
F35 ONLY torque specs.
Frame-to-Body Bolts
First Pass
90 N·m
60 lb ft
Second Pass
45 degrees
Final Pass
60 degrees
Front Transaxle Mount Through Bolt
55 N·m
41 lb ft
Front Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
38 N·m
28 lb ft
Left Transaxle Mount Bolts
55 N·m
41 lb ft
Left Transaxle Mount Bracket-to-Transaxle Bolt
55 N·m
41 lb ft
Rear Transaxle Mount Through Bolt
90 N·m
66 lb ft
Rear Transaxle Mount-to-Frame Bolts
60 N·m
44 lb ft
Rear Transaxle Mount-to-Transaxle
55 N·m
41 lb ft
Old Dec 7, 2014 | 12:42 PM
  #110
Former Sponsor
They all look correct, assuming you got these from the GM shop manual.
