Fog light differences
Old 03-08-2017, 05:19 PM
Technical Moderator
Here is one for a 2007:
21992589 | eBay
All of the switches just snap in.
Does your car already have the harnesses? The switch seems to have changed in 2008, I don't know about the wiring.
donbrew is offline
Old 03-08-2017, 05:21 PM
Fog Light Switch ACDelco GM Original Equipment 15933137 fits 08-11 Chevrolet HHR | eBay
Is for 08 and up, this Rockauto link shows the correct 2007 switch
More Information for STANDARD MOTOR PRODUCTS FLA1059
GM shows it's obsolete
http://www.gmpartsdirect.com/oe-gm/21992589
Oldblue is offline
Old 03-08-2017, 05:30 PM
Technical Moderator
Yes, they did change I don't know the difference. Looks to be a different shape, I don't see a difference electronically.
Chevrolet GM OEM 06-07 HHR-Fog Lamp Switch 21992589 | eBay
Here is the wiring for 2007
donbrew is offline
Old 03-08-2017, 05:38 PM
Technical Moderator
If the only difference is the shape, it might be cheaper to get a new waterfall from a 2008+.
donbrew is offline
Old 03-08-2017, 06:20 PM
Liquidh8's Avatar
Thanks guys. I did get the 07 schematic from Mitchell pro on demand, I was going to compare the 08 but you already confirmed electrically they are the same. I had thought about getting a newer waterfall and just going that route.
I searched eBay too and didn't find a switch, but you did, man you guys are good.
Liquidh8 is offline
Old 05-27-2017, 12:28 PM
aradmahogany's Avatar
anyone have an idea on how to remove the blank switch for fog lights on an 06? Does it pry off? Accessible from up top by removing the storage bin? I have an idea of using that space to make a mounting spot for my phone but I need to get that blank out of the way first!
aradmahogany is offline
Old 05-27-2017, 12:36 PM
Technical Moderator
I thought that you just pull the waterfall off and access from the back?
donbrew is offline
Old 05-27-2017, 01:13 PM
Probably. I just didn't want to go digging around if I didn't have to. I also figured you might be able to be sneaky and go in from up top.
Old 05-27-2017, 02:30 PM
Nope you need to pull the waterfall
Oldblue is offline
Old 05-31-2017, 10:07 AM
Liquidh8's Avatar
Yes, pull the waterfall and access from the back.
Liquidh8 is offline
nacademus
08-28-2011 08:35 AM
sleeper
2.4L Performance Tech
7
08-28-2009 11:17 AM
GWDavis28
03-21-2009 09:43 AM
mchuntley
06-10-2008 10:52 PM
RUDEINC
08-21-2006 01:20 AM
Quick Reply: Fog light differences
