How To Change 2008 2.2L Knock Sensor
Old 03-31-2011, 01:22 PM
socalHHRguy's Avatar
Like some other owners, I was getting sporadic "Knock Sensor Related" DTCs.
Bought a replacement from dealer ($36 w/CA Sales Tax - "same day special order").
Here is how I did the changeout. (Apologies beforehand for any picture quality issues - this is the first time I've posted with pix. In particular, #7 is quite fuzzy and the note on it is in pretty small type.)
TWO CAUTIONS:
(1) BE SURE TO CHECK FOR THE OLD BOLT RETAINING O-RING (see PIC #7 & 8)
(2) DISCONNECTING THE BATTERY IS *** AN ABSOLUTE MUST ** FOR THIS R&R!!!
FAILURE TO DO SO COULD RESULT IN EXPLOSION/FIRE AND/OR SERIOUS DAMAGE TO THE VEHICLE AND/OR TOOL BEING USED AND/OR SERIOUS BURNS TO YOUR BODY!!!
From personal experience, I saw the third degree burns a friend suffered when his nice stainless steel Seiko watch band shorted Battery Positive to Negative/Ground/Chassis.
NOT PLEASANT.
DISCONNECT THE BATTERY BEFORE STARTING THIS R&R.
The easiest place to remove the negative battery connection is at the battery back under the cargo area floor (10mm socket).
socalHHRguy is offline
Old 12-20-2011, 08:05 AM
jime2000's Avatar
Thank for the help will be replacing my knock sensor today.
jime2000 is offline
SwaintaN
12-22-2013 05:32 PM
DaneyKakes
02-06-2012 03:41 PM
landis327
11-07-2011 03:06 PM
artdshay
11-21-2010 02:53 PM
arclightzero
06-16-2010 12:20 PM
Quick Reply: How To Change 2008 2.2L Knock Sensor
