Running board mounting bolts
Old 07-31-2016, 01:07 AM
bowtieboy68's Avatar
I got a set of used running boards, had them painted to match, and now am ready to mount them on the wagon.
One problem though: they did not come with the bolt that mounts the bracket to the body of the car. I noticed that the diameter of the hole on the bracket is smaller than the hole on the car.
Can anyone tell me what is used?
Is there an expanding insert that goes into the body, then the bolt?
What size?
I'd HOPED to have them on this weekend....PLEASE HELP!
bowtieboy68 is offline
Old 07-31-2016, 08:51 AM
Technical Moderator
IIRC, there is a nylon insert. I think they are re used from the old rocker.
https://www.chevyhhr.net/forums/how-...iewpoint-5750/
And if you are patient there is some useful info here:
https://www.chevyhhr.net/forums/how-...g-boards-1138/
donbrew is offline
Old 07-31-2016, 09:05 AM
Unfortunately, the only things "in there" were the push in clips holding the lower panel.
nothing to reuse :'(
Old 07-31-2016, 09:16 AM
Technical Moderator
I know that NAPA has a book full of fastener samples.
There seems to have been at least 3 designs used for mounting.
donbrew is offline
Old 07-31-2016, 11:14 AM
Don nailed it, the running board fasteners did change during the run of HHR production.
For the exact OEM fastener part numbers for your '06, click the link below and pull up the parts breakdown for your HHR.
OEM GM Parts Online | Wholesale GM Parts Online
843de is offline
Old 07-31-2016, 12:25 PM
I looked on that site, and can see what's needed, but it's not listed!
I'm thinking about just getting some self tapping screws to take the place of (number 4 on the diagram) them.
Old 07-31-2016, 12:34 PM
Here is the part number for #4
EDGE MOLDING BOLT | Genuine GM | 11561637
Per
2007 Chevrolet HHR RUNNING BOARD
Oldblue is offline
Old 07-31-2016, 12:37 PM
damn.
guess i'm not very good at details. lol
so, what are the plugs that are used for the remaining holes?
Old 07-31-2016, 12:54 PM
Technical Moderator
I would put a plug of silicone in the holes to prevent rusting, if I cared enough.
donbrew is offline
Old 07-31-2016, 12:56 PM
kinda what i was thinking
Quick Reply: Running board mounting bolts
