Fan not working.
Fan not working.
I had My Check engine light come on recently and after a read it came up as a failed relay. I changed both the relay and the fuse for the cooling fan, but after reaching 220, turning on the AC, recirculating the air flow, it won't turn on and the engine light is still on. My next task is going to be wiring the fan directly to the battery(temporarily) to see if it still works at all.
If the fan runs, and has no bearing problems, what could be causing the problem?
2009 2.2 Automatic LS
Ah, well look for loose ground wire connections
https://www.chevyhhr.net/forums/prob...ing-fan-23808/
alfolsee2000
03-11-2022 09:22 PM
