Doors Fail to AutoLock
This started on Sunday. I checked the DIC and nothing changed. It usually locks when in Drive and unlocks when in Park. Stopped doing that.
My hubby also noted hard shifting but that has since stopped.
And now when I hit the brakes while driving, I can hear a clicking noise in the gear shift area.
Calling the dealership TODAY!
to the forum madred!
I moved this post into a new thread, one of the problems with tacking a question onto a thread that's 7+ years old is that the OP, in this case bowser625 left the Forum in 2008.
The clicking sound you hear when you depress the brake pedal is the "Brake/Shift Interlock Solenoid" functioning. It's designed to keep the shifter locked in Park until you depress the brake pedal, a safety feature that dates back to the 1980's when Audi 5000's were flying through garage walls when folks got their feet confused and yanked them into Drive with the throttle depressed.
In your case it sounds like a failure in the correlation between the Shift Interlock and the BCM(Body Control Module) which is an electronic module that controls the locks etc.
You can try giving your HHR a "Lobotomy" as we call it here, disconnect the NEGATIVE battery cable at the battery for 30 minutes to reset all the various modules to their factory defaults. Then reconnect the battery and see if the problem persists, if it's still not properly engaging the Auto-Lock function, I'd suspect a failure in the shifter or the need to have the vehicle checked by a technician using a Tech II Scan Tool to see if the BCM is seeing a request to engage the locks.
Another point worth mentioning, your battery might be starting to fail, as HHR's are known to go slightly "nuts" with low battery voltage. So having an auto parts store check the battery is not a bad idea, since an "undervolt" condition will cause problems.
tonykof
12-16-2011 09:45 PM
