ignition key stuck
Old 12-13-2008, 12:41 PM
jethro's Avatar
ignition key stuck
Has anyone experienced the ignition cylinder not turning completely to the off position? I am not able to get the key out without jerking and wiggling around on the gear shift . It will finally turn to the position to allow the key to come out, but sometimes takes forever. Would this be a sensor or something like that, not getting the message that the Transmission is in the Park position?
jethro is offline
Old 12-13-2008, 06:07 PM
Old Lar's Avatar
Recall issue for the '06s. I thought the problem was taken care of on later years. Take it back to the dealer.
Mine went back in and the dealer fixed the issue.
Old Lar is offline
Old 12-15-2008, 04:10 PM
jethro's Avatar
fixed under warranty
I took my 06 HHR in to the dealer today and they did the repair under warranty. It was a control unit under the gear shift column. A $ 370.00 part and 1.5 hrs labour.
jethro is offline
Old 01-13-2009, 03:13 PM
John Lupanoff's Avatar
It is the shifter/lock mechanism. There is a small door on bottom of steering column. Pry it open, push button inside and remove key.
John Lupanoff is offline
Old 01-13-2009, 06:44 PM
thedonn007's Avatar
There is a recall for this now?
thedonn007 is offline
Old 01-13-2009, 09:34 PM
NO. There is a TSB, but no recall.
jx3 is offline
dande54
08-11-2023 09:52 PM
gfsloan77
08-27-2013 08:51 PM
Locojoe1
07-07-2013 09:04 AM
Pimphand
05-26-2012 12:46 PM
dhansen871
08-22-2010 01:02 PM
Quick Reply: ignition key stuck
