Horn honks when I use the key
Old 06-07-2010, 03:17 PM
mikiec's Avatar
My FOB is dead. I have been using the key to unlock the car and when I do the horn beeps until I put the key in the ignition. I looked through the DIC to see if there was an option to solve this but I did not see one. Any Ideas how to make it stop?
Mike
mikiec is offline
Old 06-07-2010, 03:21 PM
mikiec's Avatar
Never mind. Futher searching and I found my answer.
Mike
mikiec is offline
Old 06-07-2010, 03:22 PM
ecl
ecl's Avatar
Mine did the same thing and the only way I got it to stop was a new FOB.
ecl is offline
Old 06-07-2010, 09:18 PM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
lock your door with the key then open it with the key and it will not sound the alarm.
I posted this a couple years ago...
TomsHHR is offline
Old 06-07-2010, 09:19 PM
urbexHHR's Avatar
Yeah...I think that's kinda a dumb feature... I remember that happening when I looked at one back in '06 the dealer was explaining on how it would do that when I went out and unlocked it since he didn't have the FOB on it...
urbexHHR is offline
Old 06-08-2010, 12:04 PM
BlackScreaminMachine's Avatar
Same thing happens with my Trans Am, if the Alarm is active and I use the key to manually get in, the Alarm does go off but when the ign. key is turned on, it stops
BlackScreaminMachine is offline
Old 06-14-2010, 02:01 PM
mikiec's Avatar
Tom,
That's what I read. One problem is you must lock all doors manually. If you lock them with the auto lock button, unlock the drivers manually to exit the vehicle and use the key to lock. The alarm will still go off.
No longer an issue as I re-soldered my battery connections on the FOB.
But, there still should be a way to turn off the security feature.
mikiec is offline
macarchie
12-31-2014 03:03 PM
kwe45919
10-31-2012 12:09 PM
B@work
08-19-2011 10:58 PM
speedster
06-19-2010 04:58 PM
grocerygetter
12-26-2009 10:50 PM
Quick Reply: Horn honks when I use the key
