Video of my car noise
Old 03-23-2014, 02:23 PM
jawscardodger's Avatar
I have a 2007 LS auto trans. This noise can be heard inside the drivers side wheel well. You can't hear it from the top under the hood.
http://s205.photobucket.com/user/jaw...51670.mp4.html
jawscardodger is offline
Old 03-23-2014, 02:49 PM
Nightwalkerhemi's Avatar
I have no idea what that is but to get some more info from you so someone can help,miles,engine size,and does noise change in gear,or driving.
Nightwalkerhemi is offline
The video link appears to be broken or not working.
Could you try and describe the noise.
Is it a buzzing, rumbling, rattling, or scraping sound?
He has an LS Nightwalker, so that means a 2.2L L-61 engine but the mileage on the vehicle and the conditions under which thr noise occurs would be handy to know too.
843de is offline
Old 03-23-2014, 03:04 PM
Sounds like buzzing,rattle sound,like a VERY loose rocker arm but wonder does it change with engine revs.also is there hp loss,running ok??
Link worked on my iphone,sorry didn't see the ls part.
Old 03-23-2014, 03:22 PM
For some reason my i-Pad doesn't like his video link, but based on your description, I'd hazard a guess and say it's the flex pipe or a broken airbox bracket.
I'll go back and edit his post to put the LS in capital letters, missed it the first time I read the post too.
843de is offline
Old 03-23-2014, 03:26 PM
car runs good. only way i knew it was there it i was checking the tires for wear doesn't seem to change with rpms
here's another link
Old 03-23-2014, 04:45 PM
Hi jawscardodger,
Thank you for the video. I understand that you have a noise coming from one of the wheels on your HHR. I cannot guarantee anything but please feel free to contact us if you would like for us to look further into this. We can be reached via private message if any extra help is needed.
Kristen A.
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 03-23-2014, 05:32 PM
Lucky's Avatar
My first thought would be a transmission valve rattle. Does the noise change when put in gear or go away while driving.
Is the noise there when cold or only after the engine warms up?
I had a purge valve make a noise close to that but was only there once the engine warmed up and the purge valve was operating.
Lucky is offline
Old 03-23-2014, 06:56 PM
I had the car on jack stands. Its there in in gear or not hot or cold its there all the time. But you can only hear it if you put your ear down by the wheel well standing next to the car you can't hear it
whopper
"How To" Tutorial Library
11-26-2013 10:43 AM
HHR321
02-17-2007 11:18 AM
Quick Reply: Video of my car noise
