Mounts turbo and wires
Old 12-05-2010, 11:26 AM
IgottaWoody's Avatar
Finally got the car in this past week for motor mounts , turbo drop off and some other minor items.
1) Dealer says motor rocks over excessivly but "GM" see's no problem with it, unless they fail....TTR mounts on wish list
2) Re-wrapped wires on lower sensor, so far so good...he says he doesnt know what else to do , even though I mentioned spacing the IC back away
3)Found a wire harness TSB and said I had a wire chaffed thru the coatings...hmmm...explains how smooth it felt after getting it back and also why sometimes it would run rough, likes water in fuel. This would be the inj harness wires.
4) Just started getting a light knock in rt front over curbs and speed bumps in a turn...they actually found the link bad, I was surprised as it was barely there...or else he just ran with the TSB and are changing them...parts on order.
700 miles to bust the 36 mark....cuttin it close....otherwise runs great
IgottaWoody is offline
Old 12-05-2010, 01:14 PM
Former Sponsor
TurboTechRacing's Avatar
Oh I thought you had the TTR Mounts already... :) Glad to see they are on your list.
TurboTechRacing is offline
Old 12-05-2010, 05:15 PM
Been waiting for what the dealr would say....even though I was expecting they wouldnt address it...but now everybody knows...so, new mounts it is!
stranger
2.0L Performance Tech
51
07-25-2017 04:48 PM
bigjacksauto
11
08-14-2013 01:03 PM
Father Azmodius
08-08-2010 04:29 PM
Lee3333
06-18-2006 11:04 PM
Quick Reply: Mounts turbo and wires
