Recommended replacement motor and transmission mounts?
Flex pipe broke and it's due to the motor mounts being bad. I got a quote for the repair and the two front motor mounts and the two transmission mounts are around $129 a piece. It's going to cost $1.2k to get them replaced. I went online and found motor mounts and whole kits for way less. However, for all I know they are trash quality and will break right away, so I came here to see where you all buy your mounts. Help me save some money please!
Usually you only need to replace the upper motor mount , over on the passenger side . All you need to do is support the engine with a floor jack and a piece of wood under the oil pan , just support it don’t lift it! And then remove the three 15 mm head bolts and 2 18 mm nuts. Lift out the mount and slide in the new one. I installed the Anchor brand for my automatic transmission listed in here
https://www.rockauto.com/en/catalog/...tor+mount,5552
As for the front and rear transmission mounts they are also fairly easy to change
https://www.rockauto.com/en/catalog/...ion+mount,8616
