Knocking in Engine... 07 LS
Old 01-11-2014, 09:54 PM
  #41
SwaintaN's Avatar
ok so we both work and i mean work a lot of hours.. so we are just now getting back to it, further investigation shows one of the tensioners has failed... so we are going to replace that.. everyone told us to stop where we are at and just do a compression test.. not happening...
however... we took the plugs out, and looked inside at the valves.. one of them has a gold mark inside while the rest are just carbon.. what in the world would cause a gold mark?
SwaintaN is offline
Old 01-12-2014, 12:02 AM
  #42
Worst case scenario, a strike from the piston crown on that cylinder, or a cracked head allowing the valve to be "steam cleaned" as the engine ran.
Old 01-24-2014, 09:02 PM
  #43
SwaintaN's Avatar
update
Ok mind blown... powww.. thats my mind...
Ok brand new timing chain and timing components.. brand new water pump (figured while all was off why not)
brand new belt and belt tensioner.
all new seals and oil.
start er up... KNOCK KNOCK KNOCK.... yeep still doing it.. there was about 1/2in in slack from old chain paired to new chain.. so it had to be done anyways..
someone suggested pull the coil pack to the plug that we are hearing the noise from just for a short sec. did so... plug 1 (far passenger side). when you pill the coil it STOPS instantly knocking. replug it starts again... So we switched it coil pack w/ number 4 (no sounds coming from 4). Still doing it at 1. Switched spark plugs from 1 to 3 (no sound coming from three) still knocking.. So eliminated the coil pack and plug. Only have the knocking when cylinder is firing..
Now what? Im pulling my hair out thanks!
SwaintaN is offline
Old 01-24-2014, 09:11 PM
  #44
Bad connecting rod bearing or bad wrist pin bearing on the affected cylinder, time to either tear down the engine for a rebuild, or pull it and replace it with a used/reman engine.
Your current engine is on borrowed time, you're going to suffer a catastrophic failure sooner than later I'm sorry to say.
Old 01-24-2014, 10:20 PM
  #45
SwaintaN's Avatar
thats what i figured to.. now comes the fun part.. which im not gonna do two threads.. i already started the other. will a 2.4 fit into a 2.2 area
SwaintaN is offline
Old 03-25-2014, 12:16 PM
  #46
SwaintaN's Avatar
replacing the motor this summer.. its going to cost 1k to fix, or 450.00 to replace with lower miles to begin with.. so replacing it this summer... noone can really determine now wtf is wrong..
SwaintaN is offline
grannydeb
05-08-2014 07:35 AM
Mischevious
10-10-2012 02:37 PM
DTHarris
11-11-2011 02:58 PM
ginginee
02-03-2010 09:42 PM
ian
01-19-2007 10:12 PM
Quick Reply: Knocking in Engine... 07 LS
