P1174
Old 08-26-2008, 09:02 PM
sunbound's Avatar
P1174
ok, so tonight my check engine light came on.
I pulled over, and scanned for codes using my scanguage II, and the code thrown was P1174.
for an 08 it says its "Fuel Trim Cylinder Balance".
Not exactly sure what this means.
anyways, I cleared the code and and continued on my way. I was about 20 miles from home when this happened, and the check engine didn't come on again.
I have noticed that my economy isnt as good as it usually is. I usually get around 37 MPG @ 55. it dropped to 35 MPG.
I use the unleaded plus (kwik trip)for gas, and haven't had any problems till now.
about two tanks ago, I tried "sea foam" and didn't seem to have any problems.
Is this something i should worry about? something i should have the dealer check out? I'm sitting at just over 30K on this car.
Thanks guys
Sunbound
sunbound is offline
Old 08-27-2008, 06:32 AM
sunbound's Avatar
My car thre a new code this morning on the way to work, and its not on the list B2AAA...
Oh, I noticed i didnt mention the car i have
06 HHR 2LT.
Anyone have any ideas?
Thanks guys
Sunbound
sunbound is offline
Old 08-27-2008, 06:48 AM
hhrcrafty's Avatar
Bad O2 sensor or cats. The seafoam MAY have KO'd them, but you'll have to have the dealer or your mechanic check them out.
hhrcrafty is offline
Old 08-27-2008, 10:12 AM
pitbull76's Avatar
You're still under warranty. Use it.
pitbull76 is offline
Old 08-29-2008, 08:08 AM
sunbound's Avatar
In the past two days, the check engine light hasn't come back on after i cleared the codes with my scanguage.
Do you think there is still cause for concern, or do you think its alright?
I havn't had time to take it into the dealer to get it checked on. (gotta love going back to school)
Thanks
sunbound is offline
Old 08-29-2008, 08:32 AM
Thanks
P1174 is usually set by dirty/restricted fuel injectors. Since you cleared the codes there is no sense taking it to the dealer unless it returns. If there are no codes the dealer will do no further diagnostics.
Old 08-29-2008, 11:07 AM
sunbound's Avatar
Thats what i figured.... if the codes return, ill take it in.
Thanks
sunbound is offline
jschmieding
01-02-2019 08:20 PM
jdevries
01-02-2015 12:09 PM
justinrsetzer
05-01-2012 02:44 PM
Tony_SS
01-10-2011 12:18 PM
Quick Reply: P1174
