P0013
Old 10-07-2016, 10:05 AM
suburban's Avatar
P0013
Hi, My 2008 HHR SS started throwing code P0013. When I looked online it says it is oil control valve. Is this the PCV valve or is it different? Also where is it located on the motor? Please advise...Thanks, Wayne
suburban is offline
Old 10-07-2016, 10:11 AM
aradmahogany's Avatar
https://www.chevyhhr.net/forums/how-...a-28779/page4/
aradmahogany is offline
Old 10-07-2016, 10:55 AM
Have a read here
https://www.obd-codes.com/p0013
Oldblue is offline
Old 10-13-2016, 09:54 AM
andyb's Avatar
Lightbulb
p0013 - - the exhaust cam VVT solenoid failed - - very common on the GM 4 cyl's - - it's a cheap & easy fix - it's on the top of the valve cover on the passenger side - - you will see 2 solenoids - - look closely at the valve cover & you will see a mark IN for intake & ex for exhaust - - -it will be the rear one - closer to the firewall, since our exhaust is on the firewall side. you need to raise the air cleaner box a bit - - you will need a 10mm socket to remove the solenoid - - - btw - o'reilly auto parts has them in stock - about $45 - - & they have a lifetime warranty, as opposed to a 1 yr warranty from the chevy dealer
andyb is offline
Old 10-14-2016, 04:22 PM
suburban's Avatar
P0013 code
I replaced the exhaust solenoid today. Thanks for the help and response from all. Wayne
suburban is offline
Old 10-14-2016, 05:21 PM
Your welcome, and welcome to the site!!
Oldblue is offline
whopper
"How To" Tutorial Library
633
07-18-2016 01:28 PM
sam4svita
12-24-2014 08:51 PM
dkennedy1282
11-17-2014 09:22 AM
Jm082080
07-25-2013 11:39 AM
mmont50
06-07-2012 06:25 PM
Quick Reply: P0013
