2.0 LDK Build
Old Aug 13, 2016 | 11:57 AM
  #111
Powermizer's Avatar
Look at post 239 and you can see what I did.
Old Aug 13, 2016 | 12:21 PM
  #112
hhrfreek's Avatar
I saw that thread and just buzzed through it again. I explained it in a confusing way...Its simple in my mind. I'll post pics when I get to it.
Old Aug 14, 2016 | 07:27 AM
  #113
DrLoch's Avatar
My thoughts are 2 are needed as well. I'm trying/testing to find the the best method that gives the best separation/removal of the oil vapor. I used the metal scrubbing material and didn't get the results I wanted, have switch to a different filtering material to see if it works better. I also have yet another method on the drawing board to try.
Old Aug 14, 2016 | 01:14 PM
  #114
hhrfreek's Avatar
Ok so heres what Im doing. I drilled and tapped for 1/8" NPT in the cover and head. I will use 90 degree fittings pointing towards the front of the engine to mount a catch can using a couple valve cover bolts. In order for this to work you just need to separate the valve cover and head. I am probably just going to use a very thin piece of sheet metal(because easy) and put some RTV on it and bolt the cover on to hold it in place. Or I can weld the head and/or cover shut. Doing this allows you to leave the valve in the stock location. What do you think?
Old Aug 14, 2016 | 01:55 PM
  #115
Wouldn't you have to worry about liquid oil flowing?
Maybe this is just another "I don't understand" thing.
Old Aug 14, 2016 | 02:19 PM
  #116
hhrfreek's Avatar
Nope just oil vapor in these ports. I actually just cut a small piece of pop can and used rtv and bolted the cover on. Unless I completely overlooked something elementary, I think this should work great.
Old Aug 14, 2016 | 03:51 PM
  #117
Powermizer's Avatar
I am fine if we want to change my build to a oil catch can thread. I am not far from being done anyway. Lol
I need to look at my head closer to see what you are doing.
Old Aug 14, 2016 | 05:25 PM
  #118
That port you've blocked off(I'm surprised I didn't look down in there when I had the valve cover off), as long as that's not open on the bottom to the crankcase, looks like a good plan!
Old Aug 14, 2016 | 05:39 PM
  #119
hhrfreek's Avatar
No problem... Won't muck up your thread.
That center port only feeds down from the valve cover.
Old Aug 14, 2016 | 08:08 PM
  #120
Powermizer's Avatar
Im really not concerned about it. Shouldn't have brought it up. Crazy morning.
When Randy saw my setup he said he would be concerned about oil pooling and plugging a line. I want the oil to pool. If you can get it to pool you have a lot better chance of catching it in the can. About plugging, I doubt that can happen, having vacuum and serious vacuum on a down shift in gear will no doubt clear anything out.
hhrfreek It would be cool to put that info on the how to install a catch can because there is more to learn about this and you have done something different. Keep going on and let us know what your finding. Thanks!!
