2.0 LDK Build
Old Aug 17, 2016 | 12:27 PM
  #131
DrLoch's Avatar
Heater, yes although I don't/won't drive it much in the winter. Heck it's only got 38K and it a 2008. sits in the garage most of the time.
Can't get the link to work.
Old Aug 17, 2016 | 01:30 PM
  #132
Powermizer's Avatar
Got ya beat, mine is an 08 and has 14,114 just had to.!!! LOL
ya heater will work as long as you have a high and low pressure to tie into. That is where the thermostat is on our engine.
wonder if you were trying the same link...... I cant get one to attach!
Old Aug 17, 2016 | 03:37 PM
  #133
DrLoch's Avatar
With 14,114 on the clock yes you do. My drive to work is 37-39 miles each way depending on which route I take. Doesn't take long to crank up the miles.
I'll have to look at the heater connections. Would need to create a pressure drop using an orifice of some sort to make sure I had heater flow if I intended to drive much in the winter.
Old Aug 17, 2016 | 08:05 PM
  #134
Powermizer's Avatar
Ok I need help from anyone and everyone to help me decide which way I should go.
With the engine cover I had made?
Or without, and just coated valve cover?
All thoughts are welcome....thanks
Old Aug 17, 2016 | 08:06 PM
  #135
Powermizer's Avatar
Another witout
  #136
Powermizer's Avatar
With cover
Old Aug 17, 2016 | 08:07 PM
  #137
Powermizer's Avatar
Another view
Old Aug 17, 2016 | 08:08 PM
  #138
Powermizer's Avatar
One more
Old Aug 17, 2016 | 08:10 PM
  #139
Powermizer's Avatar
I am thinking of having some plates coated and put under the cutouts. Any thoughts are welcome.
Old Aug 17, 2016 | 08:13 PM
  #140
I like both. Looks like you can change up the look easily whenever you want!
