Air Flow at 23 LBS Boost
Old Apr 8, 2018 | 06:29 PM
2005HHRauto's Avatar
Originally Posted by celblazer
Wondering why the big jump from 20-26psi. The HHR computer changes boost to reach desired torque/hp. A boost jump like that to make the same numbers the computer was programmed to before the mods means you lost efficiency big time. The computer is adding 6 more PSI to make the same numbers as you did before. These are set numbers unless you changed them along with the mods.
Am I correct in understanding how the HHR computer works?
Are you correct? Yes & No
Yes our PCM is a 'torque' based PCM, that will try to keep the 'torque' limits that are programmed, under control....
A 'tune' on our engine, is mostly just increasing the 'torque' limits from mild-to-wild, to what your goals might be...
Our engine will easily exceed the stock programmed 'torque' limits all the time, & the PCM will always be trying to keep 'torque' at the programmed limits...
If you are 'free-wheeling', or exceeding the limits quickly, you will blow by the limits, as the PCM can't react quickly enough...
Example:
If your doing a 'water' burnout, with your 'speed' limiter set to say 50mph, you smash the throttle to the floor & the tires start to spin super fast, & your speedometer might be reading 100mph, as the PCM just can't shut things down fast enough...
UPDATE:
The sound that the intake makes is much louder, with a noticeable low rumble at idle...
This is an indication that this filter is definitely helping the intake tract flow more freely...
Also looked up some internet articles on filters/turbos...
One 'racer' gained 7mph in the 1/4 mile, from 127 to 134, by just removing the filter...
Most articles stated that a good 'free' flowing filter will always have a 'positive' effect with turbo performance...
Old May 3, 2018 | 05:44 PM
Well, this filter is definitely a good performance upgrade.
This morning as I was cruising along at 45mph, I floored the 'go' petal.
Immediately the automatic downshifted into 2nd gear...
My 'buggy' started 'pulling' like a bat-out-of-hell, like it usually does...
But this time, at 60mph, the tires broke loose & started squealing for a few seconds...
It has never done this before, breaking the tires loose at 60mph, in 2nd gear...
akfinest1
Jun 23, 2012 09:06 PM
sp52075
Aug 22, 2010 10:09 AM
chitownbro1
Sep 30, 2007 08:11 AM
808jrh
2.4L Performance Tech
Sep 21, 2006 05:50 PM
