Anyone running a airbox with no lid
Sadly, not the Mile High Club you may be thinking of
What about now?
What about now?
airaid
Airaid has a topless cai....i think the sides seal to hood making the hood the top and it breathes thru the grill area...i know they have them for the 2.2 , 2.4 , but not sure about the 2.0.
Again..you are explaining air AFTER the turbo..not before...you are talking mechanically pressurized air and I am talking static atmospheric pressured air..I have no problem relating to what you say..you are correct, on the pressurized side of the turbo( exit). The entry side of the turbo will encounter the same problems as a normally aspirated motor as far as intake tubes and restrictions are concerned..you cannot magically produce ( yes..volume) so many cubes of pressurized air UNLESS your supply side allows it,,
Heres my example- simple central attic fan..turn it on with alll the windows closed and note the fan speed( read load) now open a few windows ans see how much faster the fan turns because NOW you have an ample amout of air to move and the fan is allowd to operate at max compacity..a restrictive intake tube willl do the same...must be an engineer
