BOV replacement: Forge Motorsports
Old Feb 27, 2012 | 04:13 PM
  #101
ChevyGuySS's Avatar
Originally Posted by EcotecRacer
Isn't green for up to 24psi? Yellow to 35psi?
but will it damage anything if the spring is meant for higher pressure and im not running higher pressure? wont it hold the boost in when its not?
Old Feb 27, 2012 | 06:56 PM
  #102
EcotecRacer's Avatar
It can which could cause the plastic charge pipes to bust,crack etc
Heck I blew mine with factory unit when I got dyno tuned
Old Feb 27, 2012 | 08:07 PM
  #103
ChevyGuySS's Avatar
see thats what i was thinking. i got to get a bunch of parts before i tune, i need this thing to be really reliable
Old Feb 27, 2012 | 11:11 PM
  #104
Excuse Me. did you say reliable and SS in the same sentence ?
Old Feb 28, 2012 | 12:03 PM
  #105
foxtrotraptor's Avatar
Darn genuineSabb.com is out of stock. I called and they said they ordered more and it should be back in stock in about another week.
Old Feb 28, 2012 | 01:01 PM
  #106
bad03xtreme's Avatar
Modernperformance.com
Old Feb 28, 2012 | 02:44 PM
  #107
JeramieJJ's Avatar
Originally Posted by Victory Red SS
As far as sound is concerned I'm not sure that it is much louder than stock but definitely a more robust part. I'm happy.
Nice. After 1200 miles I am very, very happy. (600+ miles on Saturday)
Response is great and no second guessing if the diaphragm swallowed the spring as you go to punch it.
As to sound.....I wouldn't know either, the downpipe drowns that.
Old Feb 28, 2012 | 02:55 PM
  #108
ChevyGuySS's Avatar
yes yes, i know! well after all my mods, hopefully it will still be reliable and now im planning on building an ls1 miata
Old Mar 2, 2012 | 12:26 PM
  #109
moonsign's Avatar
Question: does the turbo diverter valve dump boost, before the compressor wheel or after.
Also, does Forge valave have to be positioned a certain way to exhaust properly[line up with straightest path]. "Moon"
Old Mar 2, 2012 | 01:26 PM
  #110
Joe Schulte's Avatar
Before & there's an opening that when you install the Forge must face straight down. Self-explanatory once apart .
Edit, this helps!
