Detonation problem I think i found the fix
Old Jul 21, 2015 | 06:47 PM
  #41
black Tara's Avatar
I towed the HHR SS to my tuner today he found the problem right away.
This may help the explanation.
http://www.theturboforums.com/thread...-spark-blowout
He had to order me new spark plugs and re install them , then he's going to run it on the dyno to make sure there is nothing else causing any problems. He is going to turn the boost down and give me a 93 octane tune. I'll check back in when I know more!
Tim
Old Jul 21, 2015 | 06:54 PM
  #42
LT4Man's Avatar
I have 2 questions.
1. What gap have you been running?
2. What gap does your tuner recommend?
Old Jul 21, 2015 | 07:03 PM
  #43
black Tara's Avatar
keep in mind my boost was turned way up to 25, so that could be the biggest problem right there, I think?
I was running stock AC/Delcos with a 30/32 gap. I haven't talked with again and he didn't say what he was going to gap them except that he hates Iridium plugs so since they don't make a copper plug for our SS's he was going one step colder and platinum plugs.
Old Jul 21, 2015 | 07:12 PM
  #44
LT4Man's Avatar
Makes sense.
I am certainly glad that this could be the solution to your problem.
I would hate to see you damage your engine & have to invest even more money.
Old Jul 21, 2015 | 07:15 PM
  #45
Dbeluscak's Avatar
Hope that takes care of it Tim. I'm not certain about that plug blow out link you had there. Seems like if you had the problem while under heavy load, that the plugs could've failed. Wouldn't you have had misfire CELs then? Boost @ 25psi didn't help the situation any, but that's not excessively high. Did you get to look at your plugs, or are you doing all this over the phone/email? I'd be curious to see the Delco's condition.
Old Jul 21, 2015 | 07:22 PM
  #46
black Tara's Avatar
I did get misfire codes
  #47
Dbeluscak's Avatar
Well then, fingers crossed for ya!
Last edited by Dbeluscak; Jul 21, 2015 at 07:23 PM. Reason: Can never get the text size right! Ever!
Old Jul 21, 2015 | 07:26 PM
  #48
Dbeluscak's Avatar
Guess I'll be taking mine out this weekend. ZZP sent me a new set of iridiums pre-gapped. I'll find out the gap when I get home.
Got an appt with the dyno, Aug 5!
Old Jul 21, 2015 | 07:30 PM
  #49
black Tara's Avatar
you already have a tune right? Just want to get hp and torque numbers? I take it you got all those crazy codes taken care of?
Old Jul 21, 2015 | 07:39 PM
  #50
black Tara's Avatar
Originally Posted by LT4Man
Makes sense.
I got news for ya if I have to keep spending the amount of money I already have!
As much as I love this car and I really do I'd get rid of it!
I have my eye on the 2016 Direct Injection Comoro :)
