Finally..
Old Apr 12, 2012 | 11:50 PM
Sounds like you are learning the language our car speaks Breadfan. When you are ready you can fix mine.
Old Apr 13, 2012 | 01:08 AM
Breadfan's Avatar
I don't profess to be good at it yet. I try to give my input in the hopes that more knowledgable folks will curb me if I am misguided. If you were in Norcal, I'd have no problem logging it for you. I have been trying to somewhat emulate the GM tune and I did experience the loss of boost with no CEL for one key-turn.
Old Apr 13, 2012 | 04:32 AM
bigjacksauto's Avatar
Originally Posted by 10RedSS
At most I have only hit 18 19psi. On the way home tonight, it hit about 15psi then lost boost and then when I got on it again it only peaked at like 9 psi.
Keep us updated how much did the whole install cost if u font mind me asking.
Wonder if they installed the proper software with upgrade?
Old Apr 13, 2012 | 04:45 PM
10RedSS's Avatar
I know a tech at a dealer, he installed it for "lunch money". Monday I will have the ECM reflashed.
Old Apr 14, 2012 | 06:23 AM
Did the tech just install the hardware upgrade and not reflash the computer with the upgraded software?
Old Apr 14, 2012 | 08:31 AM
  #26
If I read this right. You had the kit installed but didn't do the reflash yet? If so, I recall reading that if you install the sensors without the reflash,and you drive it,then it may throw some codes. And it must be reflashed for the upgrade to work.
As far as the boost issue dropping to 9lbs as you stated earlier. Sounds like you have a leak around one of the o-rings on the new bosch sensors.
Old Apr 14, 2012 | 02:02 PM
  #27
10RedSS's Avatar
I did have the ECM flashed, monday I will get it flashed again, just to make sure.
Old Apr 14, 2012 | 03:56 PM
  #28
OK. Just trying to help here. If you're having a boost issue like you descibed in your earlier post,then a re-reflash probably won't help. If it initial boosted up to 18-19,then the reflash was good. Losing the boost later or dropping to 9 lbs as you said sounds like a leak in the system.
FWIW. Mine did the same thing. Boosted 18 on the way home from dealer. 5 miles from home, started loosing boost. Drove back to dealer and every time it tried to boost it would go to 4-5 lbs then fall on it's face. The tech looked at it and said the bottom sensor was not seated good. He pulled the sensor checked the o-ring and reinstalled. Has been fine since. 3 months.
Now. About boost pressure. Others claim 21-24. I have only seen 18-19. I made a few calls to some folks that would know. In short I was told that the 18-19 was fine. It's not how much boost, but how much power you get from the GMTU. If the car gets the power with 18-19 lbs,then thats what you'll get. Many factors come into play such as altitude,weather,air quality,etc. Maybe some of the latest upgrades have been tuned down a little by the GM reflash. Not sure. Just guessing here.
So, if you want to have it re-reflashed go ahead. BUT, I would advise looking at the sensors and/or o-rings just to be sure.
Let us know what you find out. I can always learn something new.
Old Apr 15, 2012 | 06:49 AM
  #29
russruth's Avatar
When they check the o-ring on the sensor, also have them check this.
When they install the upgrade a lot of times the tech ham handed cracks the nipple. Mine went in three times for this and they blamed the accuator and said it was back ordered for the next 10 years, until I made them throw some silicon glue on it. It ran fine for a few hourse, so they changed the hose and nipple.
Old Apr 15, 2012 | 09:04 AM
  #30
Good info russruth. Something to look at.
One question though. Why did the tech break this? In doing the upgrade, the tech shouldn't be working anywhere near this part. Makes me wonder how and why he was messing around there.
