Finally Fixed...with "some" conditions
Old Mar 29, 2012 | 04:24 PM
RobSSTurbo's Avatar
I agree with ATLsliverSS go hptuners and be done with it.
Old Mar 29, 2012 | 04:34 PM
KissMy08SS's Avatar
That's what I plan on doing...but I can't go with HP tuners until my problem...(whatever it might be) is resolved. I can't put a tune on if it's continuously throwing codes. Something has to be causing the P0101/P2199 codes...
Old Mar 29, 2012 | 04:40 PM
Breadfan's Avatar
No need to wait. HPTuners could help with the troubleshooting. You can run fairly detailed logs with it. I logged on my stock tune before making my own tune just to make sure I understood what was happening and that there was nothing to fix first.
Old Mar 30, 2012 | 04:32 AM
russruth's Avatar
Originally Posted by KissMy08SS
I replaced it too, both the upper and lower MAPs are brand new.
Since it hapens worse with the trifecta, which usually means more boost, more pressure, you probably have a leak somewhere or some part is overly stressed.
Personally, I'm ditching trifecta and going with Cobalt333 and HP tuners.
Vince takes too long to get back and for me his solutions are always limited. Nice guy, but still limited fixes.
IMO
Old Mar 30, 2012 | 11:12 AM
KissMy08SS's Avatar
IMO
Did a boost leak test...had a minor leak...nothing major. Fixed it. I too and ditching Trifecta today...getting the car reflashed with the GMS1 Tune and going with James from Cobalt SS (HP Tuners)
Old Mar 30, 2012 | 05:16 PM
  #26
KissMy08SS's Avatar
Got the car reflashed today...(at no charge!) and so far...so good. No surging issues, holds 24 lbs of boost no problem...plenty of power...no CEL. I sent Vince and email...and he is refunding me $140.00 for the Trifecta Tune. It's cost me over $300 for his tune....but I'll settle for the $140. That will go towards my HP tune!
Old Mar 30, 2012 | 05:19 PM
  #27
Nice to hear, I put the blue spring in today works better, thinking of sticking in the red one.
Old Mar 30, 2012 | 05:56 PM
  #28
KissMy08SS's Avatar
uh oh......
The car just threw a P258A-Vacuum Pump Relay Control Circuit & a P0557- Brake Booster Sensor Circuit Low Voltage
What the F does that mean?? All they did was reflash it...
Old Mar 30, 2012 | 06:24 PM
  #29
while you have the book out tell me what is P2261, mine gave me this when it flashed esc active, with the traction turned off, there was lots of tire spin.
Old Mar 30, 2012 | 09:28 PM
  #30
KissMy08SS's Avatar
Here ya go: P2261-Turbocharger Bypass Valve Stuck Closed
